Author Topic: anyone used a mtroniks W tail mixer and had any problems  (Read 6316 times)
daveorgan
« on: December 04, 2011, 04:01:05 pm »
Hi has anyone used  a mtroniks w tail mixer and had any probs
i set one up as per instructions using 2 x viper marine 20 speed controllers but seemed to only get it working on left and right could not get anything through the  throttle stick any  one else had any probs please let me know perhaps im doing something wrong but intructions are quite clear.
regards
dave
mersey dave
Re: anyone used a mtroniks W tail mixer and had any problems
« Reply #1 on: December 04, 2011, 04:17:57 pm »
Hi Mate can you tell me what tx and rx you are useing.
Regards Dave.
daveorgan
« Reply #2 on: December 04, 2011, 04:22:11 pm »
planet t5 had it a couple of years its perfect like i said i connect everytthing up as per the instructions but got nothing on forward reverse stick but everything works perfect on lleft and right ie motor slows and does what it should  do.
thanks
john s 2
« Reply #3 on: December 04, 2011, 04:22:43 pm »
As mtronics have a bec in every Esc,  have you disabled the bec in one of the Esc,s? John.
daveorgan
« Reply #4 on: December 04, 2011, 04:24:34 pm »
yes i have removed one bec
mersey dave
« Reply #5 on: December 04, 2011, 04:26:47 pm »
Does The rudder work ok.
Regards Dave.
daveorgan
« Reply #6 on: December 04, 2011, 04:28:53 pm »
should i  set the speed  controllers up first then connect the mixer as i had it all set up then tried setting the speed controllers you know turning on pressing buttons pushing stick forward aand back i did this with mixer connected , if i remove mixer everything works as it should i have throttle etc ,
daveorgan
« Reply #7 on: December 04, 2011, 04:29:28 pm »
rudder works fine too
mersey dave
« Reply #8 on: December 04, 2011, 04:33:27 pm »
Ok Dave, have you tried swaping over the plugs to the rx, if not  and this works you will need to swap over the rudder
Regards Dave.
daveorgan
« Reply #9 on: December 04, 2011, 04:36:58 pm »
ill try that dave and let you know how i get on thanks for the help mate
regards dave
mersey dave
« Reply #10 on: December 04, 2011, 04:39:49 pm »
ok dave, i have done two of them and it is not as easy as they make out.
Regards Dave.
daveorgan
« Reply #11 on: December 04, 2011, 04:41:54 pm »
so shoould i set up speed controllers before adding the mixer.
regards
mersey dave
« Reply #12 on: December 04, 2011, 04:50:06 pm »
No it is like you said every thing works without the mixer, and like they say the two plugs from mixer to tx, one goes to the rudder channel and the other goes to the throtle channel.
mersey dave
« Reply #13 on: December 04, 2011, 05:06:30 pm »
Hi Dave, How are you getting on.....any luck.
Regards Dave.
daveorgan
« Reply #14 on: December 04, 2011, 05:12:52 pm »
all working mate for some reason i had to change plugs over in  reciever to me its ass backwards but it works mmate
thanks for your help
regards
dave
mersey dave
« Reply #15 on: December 04, 2011, 05:17:58 pm »
yes thats what they don't tell you as in which speed controller plugs in which side of the mixer. and this does make a difference.
regards dave.
daveorgan
« Reply #16 on: December 04, 2011, 05:20:40 pm »
thnks mate thought i had a duff mixer
thanks again
dave
Page created in 0.181 seconds with 22 queries.
