Author Topic: What tool to use to trim an abs hull  (Read 3663 times)
Miles
« on: January 15, 2012, 03:56:37 am »
After working through the lack of any 'how to' instructions in building a Billings Smit Neterland I have concluded that I need to trim the top of the hull moulding. I have a rotary tool kit and am about ready to make a test cut.
Can anyone advise whether it's best to use a cutting wheel or a needle-nosed cutter - or any other advise on what to use would be appreciated.
Miles
Re: What tool to use to trim an abs hull
« Reply #1 on: January 15, 2012, 04:29:08 am »
Hullo Miles....just returned from two weeks in Adelaide when the temps were 42 degrees C  >>:-(  <:(
I do not know the answer to your question .......so just wait    <*< ...I am sure a member experienced with ABS hulls will come to the rescue....Derek
Miles
« Reply #2 on: January 15, 2012, 06:18:47 am »
Hi Derek,
Thanks for that encouragement - I'll wait.
Sorry about the temperature - it normally only gets that hot when we have visitors   8)
Miles
« Reply #3 on: January 15, 2012, 06:30:46 am »
Hi Miles
As a preference I would suggest the wheel, however I find a junior hacksaw a better proposition followed by a file.
I find there is less chance of mistakes ie wheel snatching and going its own way.
Hope this is helpful.
HS93 (RIP)
  • I cannot spell , tough
« Reply #4 on: January 15, 2012, 06:42:56 am »
I have found this OK to use I just G clamp a lenght of 25 x 50 (2 x 1 in old money) and rest the hull over it , I find I can controle it better than other methods I have tried but I tend to like to use hand tools when I can.
Peter
Chuffy
« Reply #5 on: January 15, 2012, 09:47:48 am »
Like Peter I would go for the razor saw every time, especially if the cuts an important one, just keep your fingers behind the direction of the saw though, ABS can be a slippery material to work with and the shape of the hull won't help much. DD has already pointed out the drawbacks of using a wheel plus I find that the ABS very often welds it's self back together again following the cut.
Paul
LarryW
« Reply #6 on: January 15, 2012, 10:31:01 am »
HI MILES,
             My method fix masking tape on cut line mark cut line on tape if straight cut clamp on srtaight edge i use a steel ruler.
               curvy bits aslow and steady light scrib cut using several strokes , the tape stops the knife  having its own way .
 i build a lot using styrene sheet and this  the way i cut that as well also my steel straight edges have a cork anti slip mat fixed on back,
      to finish a light sand of using sanding board to finished mark .     hope this helps  LARRY......PS  HEATH @ SAFTY KEEP FINGERS BEHIND CUT TOOL KEEP BAND AIDS HANDY.. {-) {-) :-))
Deep Diver
« Reply #7 on: January 15, 2012, 01:42:20 pm »
I all ways go for a Block Plane, some times called a smoothing plane.  ie a small wood plane
Captain Flack
« Reply #8 on: January 15, 2012, 07:16:59 pm »
A powered rotary saw tends to melt  its way through.  Stick to hand tools where you can.
Miles
« Reply #9 on: January 16, 2012, 07:13:42 am »
Thanks to all you guys who replied.  I really appreciate the help and I think you have saved me from making a big mistake.
Thanks again to everyone.
Miles
Page created in 0.13 seconds with 22 queries.
