Author Topic: Any ideas?  (Read 5451 times)
Patrick Henry
Any ideas?
« on: February 03, 2012, 11:52:25 am »
Any ideas as to what this may be? Marked as a "Snoopy Switch" and made by Mole Technolgy.
On the back of the case is a sticker marked "JR/FUTABA" made in Great Britain, and a small sticker stating "PASS".
Re: Any ideas?
« Reply #1 on: February 03, 2012, 12:15:47 pm »
I would imagine  (no experience)  that it was a switch (or slowstart ?) that is driven by the receiver.
Try plugging it in to a channel and connect an Ohm meter across the two wires. Measure the connection points when you operate the radio.
Best of luck
Ken
hollowhornbear
Re: Any ideas?
« Reply #2 on: February 03, 2012, 12:25:16 pm »
mole technology were electric flight specialists some years ago, so would think along those lines, probably a soft start switch for the motor. simple off on.
best guess.
Patrick Henry
Re: Any ideas?
« Reply #3 on: February 03, 2012, 12:29:20 pm »
Thanks Kev and Ken...
I'll give it a try and see what happens. Stand by for a big bang and a lot of smoke....
Subculture
    • Dive-in to Model submarines
Re: Any ideas?
« Reply #4 on: February 03, 2012, 12:39:53 pm »
If you can open the case and take a picture, that will tell us a lot more.
Re: Any ideas?
« Reply #5 on: February 03, 2012, 01:23:07 pm »
Patrick Henry
Re: Any ideas?
« Reply #6 on: February 03, 2012, 01:26:39 pm »
No can do, Andy...it's a sealed case.
Martin...thank you so much for the vote of confidence.  >>:-(   >:-o  grrrr.....
Patrick Henry
Re: Any ideas?
« Reply #7 on: February 03, 2012, 01:42:58 pm »
Can't try it out...don't know what wire goes where?
Obviously the Futaba plug goes into the rx, but the two heavy back wires...do they go to the battery pack? Or to the motor?
Subculture
Re: Any ideas?
« Reply #8 on: February 03, 2012, 01:45:43 pm »
No such animal. Unless the rascals potted it in resin, then you're 6uggered!
Re: Any ideas?
« Reply #9 on: February 03, 2012, 01:51:20 pm »
We know the plug goes into the R/X
Therefore the other two wires must be controlled to short out. Until you've metered them with ohms we're not gonna know.  Don't panic Mr Mannering. Try it first please.
ken
Patrick Henry
Re: Any ideas?
« Reply #10 on: February 03, 2012, 01:58:01 pm »
It's a totally sealed case, Andy...no way in or out, no joins visible anywhere. Very much like a monolith...
Ken...I'll give it a try later, fear not. I'm just wondering though, where does it get it's power from?
Re: Any ideas?
« Reply #11 on: February 03, 2012, 02:00:31 pm »
Just think of it as a switch in one of the leads from battery to motor /lights/servo etc.
If you haven't got a meter just connect one end to a battery and the other to a lamp
 on the pos and a straight lead on the neg and when activated the lamp should light.
simples
Subculture
Re: Any ideas?
« Reply #12 on: February 03, 2012, 02:04:35 pm »
The power for the electronics inside would come from the receiver plug. The two other leads are likely just switch a positive or negative feed. If it's relay based you could try plugging the receiver lead in with some power to the receiver. If it's relay based you may be able to hear it clicking on and off when you operate the appropriate channel with your transmitter.
But it's probably transistor based, so you won't hear squat, which means you need the ohm meter as mentioned.
Re: Any ideas?
« Reply #13 on: February 03, 2012, 02:09:02 pm »
There was a guy in Jersey making a similar box. His had three wires which was very helpful as it acted as a two way switch.  Push the T/X lever up and the centre wire joined to one wire.  Pull the lever down and the centre wire switched over and joined the other wire.  Very handy.
I believe the connections stayed joined until the T/X was pushed up and down again.  (hey, it's not easy describing this electric stuff !!)
ken
Re: Any ideas?
« Reply #14 on: February 03, 2012, 02:14:26 pm »
Thats called latching Ken.
OK for lights etc
The other is momentarily
OK for horns and whistles etc
