bluebird... I hadnt remembered posting those pics.
i was trying to get the boat to respond to the rudder. in its original form, the boat had a 40 ft turning circle.
The kort nozzles didnt work, they were scrapped. The shorter shaft is the one now being used, as the blade is much closer to the hull, and also the rudders, which I have enlarged. But I have found the problem, in that somehow the shafts and tubes got mixed up with another set I had and the shaft is 4.5mm, but the tube is 5mm.
Due to minimum space on the tubes, most of the suggestions here wont work. I have tapped the lower ends of the tubes over with a toffee hammer, and have now succeeded in making one side watertight, and the other side significantly less leakage. the other tube needs a second application of hammer
I'm using some castrol high melting point bearing grease as well. Its looking hopeful.....
