Author Topic: Sealing a pushboat hull  (Read 2169 times)
Cyberdan
« on: February 16, 2012, 02:53:43 am »
I'm currently building a pushboat, I used 1/2 inch ply in the sides, transom and bow and 1/4 ply for the bottom and it feels pretty solid at this stage. the hull length is 68 cm and width is 31 cm.
I'm currently at the stage where I'm doing some final sanding of the filler and the wood and wanted to seal everything. This has been discussed here before and I did a few searches with many results since it seems that sealing goes down to preference and type and materials used on the hull.
Do I need to use fiberglass cloth and resin (I have 1.5 oz) how many coats should I apply after the first coat with the cloth?. Or can I omit this stage and use something like sanding sealer since this is a strong model in the first place? and how many coats should I apply?
Thanks,
Hany
triumphjon
Re: Sealing a pushboat hull
« Reply #1 on: February 16, 2012, 07:54:44 am »
if its the bare wood , sanding sealer should be more than enough it will need several good coats possibly four or five and a very light rub down between coats . jon
barriew
« Reply #2 on: February 16, 2012, 07:55:02 am »
I would at least seal the insides with resin - no cloth needed - just resin brushed well in the joins. Then you can seal the outside with sanding sealer or Easy Kote to get a good surface for painting. I am sure others will have their own ideas. When I built mine I did seal the insides with resin and used glass on the outside.
Barrie
Cyberdan
« Reply #3 on: February 17, 2012, 10:32:27 pm »
Thanks Jon and Barrie I'll try that.
Hany
