Author Topic: Multiple Charging  (Read 2650 times)
The long Build
Multiple Charging
« on: February 23, 2012, 01:54:08 pm »
If you have say 2 set of batteries both 7.2v 3300 can you charge them from the same unit at the same time ?.
Re: Multiple Charging
« Reply #1 on: February 23, 2012, 02:52:10 pm »
Big NO!
 Battery packs MUST always be charge individually, that way the charger can monitor current, voltage and in some cases, temperature.
Patrick Henry
« Reply #2 on: February 23, 2012, 03:27:39 pm »
Ooh, heck as like...I've been charging battery packs like that for years and never had any trouble.
 :embarrassed:   :D
« Reply #3 on: February 23, 2012, 03:46:25 pm »
Depends on the charger The main thing is three packs equals three times the charge time
No real advantage apart from not changing the packs after each is charged.
« Reply #4 on: February 23, 2012, 05:12:11 pm »
OK for trickle charge I guess....
nick_75au
« Reply #5 on: March 10, 2012, 06:18:11 am »
OK a bit of time from the last post, but here is my input, the best way to charge Ni-XX packs is in series, this is the way the chargers algorithm is expecting to see the battery. Charging and discharging in parallel isn't recommended for Ni-XX.
Nick
« Reply #6 on: March 10, 2012, 10:01:56 am »
If they are permanently connected, they CAN be regarded as one large battery.  If they are ever disconnected and/or used separately, they will be at different stages of discharge, and recoupling them for recharging will likely not do much good.  The charger, if its a smart one, will get misleading information and either overcharge or not fully charge.  A slow trickle charge might bring all up to full charge, but will take just as long as doing them separately.
The long Build
« Reply #7 on: March 10, 2012, 10:07:29 am »
Thanks for the info, I think reading this its best to charge 1 main battery at a time to be on the safe side.. :-))
Tombsy
« Reply #8 on: March 10, 2012, 06:56:32 pm »
Lipo's can be parallel charged if they are the same cell count and the same state of charge, I use this MPA board to charge up to 6 packs at up to 40 amps.
http://www.revolectrix.com/MPA_XH.htm
