Author Topic: digefleet  (Read 3110 times)
gary r uk
digefleet
« on: April 03, 2007, 02:36:09 pm »
Hi guys
Are Diigifleet RX compatible with Futuba cristals.
is Digifleet stuff still available.
cheers
gary rowe
SAILING WITHOUT FAST ELECTRICS PRICELESS
Re: digefleet
« Reply #1 on: April 03, 2007, 05:12:34 pm »
gary,
No and no.
The crystals arent compatible, and Digifleet  I believe are up for sale again.
Re: digefleet
« Reply #2 on: April 03, 2007, 07:43:16 pm »
Not totally extinct then. I won't bin my set which needs repairs just yet.
gary r uk
Re: digefleet
« Reply #3 on: April 03, 2007, 09:46:22 pm »
Hi guys
Thanks for your infomation .
I have just come back from a night sail at Black Park,anyway i had to go into full reverse so as not to hit Holmeses WSC this was OK but after the maneuver i lost power but was able to get my Scharnhorst back to the bank with that horrible smell of burning, anyway i could not see jack on the bank but after disconnecting the power the smell  went ,back home it appears that one of the power leads came off one of the motors .Now the motors are right up against a bulkhead and under a rather large cross member taking the motor out to solder the wire back on is not possible so i have to do it in situ .well if this is the only misshap i have i will be happy,Scharnhorst will be back.
cheers
gary rowe
gary r uk
Re: digefleet
« Reply #4 on: April 04, 2007, 09:59:18 am »
Hi guys
Now that i can see whats going on in the hull of Scharnhorst in day light it is ,well not good the speed controller is OK the starboard motor is OK the port motor is not interested but wait there's more the s.board motor only goes in reverse , but everything else works.
Sensible suggestions / solutions please.
cheers
gary
Re: digefleet
« Reply #5 on: April 05, 2007, 02:08:28 pm »
Is that in reverse through the speed controller or direct from the battery.
Check the shaft isnt tightening up one way too.
Peterm
  • Inactive
Re: digefleet
« Reply #6 on: April 05, 2007, 03:26:17 pm »
I recently had a similar problem in my Riva Aquarama.   It turned out that one of the Mtroniks esc would only function in the forward mode.   I found this out when I swapped the esc`s over.   PeteM
I`m not just old, I`m ancient
gary r uk
Re: digefleet
« Reply #7 on: April 08, 2007, 03:39:26 pm »
Hi guys
Thanks for your interest the speed controller burnt out as a result of a short in the power lead to the motor still all replaced now.Holmsey will post photos sometime this week of the Scharnhorst & the nite sail.
cheers
gary rowe
Page created in 1.197 seconds with 21 queries.
