Author Topic: Cell count VS KV  (Read 2317 times)
Cell count VS KV
« on: March 07, 2012, 09:17:04 am »
Im a little confused about this
Planning on building a hydro and looking at brushless motors and batteries
surely it would be better to have a higher KV motor and a lower cell count eg 4000Kv on a 2 cell lipo than a 2000Kv on a 4cell as the 2 cell pack will weigh less than a 4 cell of the same spec (eg 4900Mah 20C)
As an example this setup
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17728
http://www.hobbyking.com/hobbyking/store/__7299__Rhino_4900mAh_4S1P_14_8v_20C_Lipoly_Pack.html
weighs in at 639g
compared to
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17702
http://www.hobbyking.com/hobbyking/store/__7653__Rhino_4900mAh_2S1P_20C_Lipoly_Pack.html
which is 411g
The above is just an example comparing like for like and not what I'm planning on using
Granted the ESC will need to be beefier for the 2s but wouldn't the reduction in battery weight still be a bonus?
Or am I missing something obvious?
Subculture
    • Dive-in to Model submarines
Re: Cell count VS KV
« Reply #1 on: March 07, 2012, 10:14:10 am »
Lower voltage means higher current for equivalent power. That puts more of a burden on the batteries. You could go for a smaller size capacity pack for the 4S setup, which will offset the weight penalty.
« Reply #2 on: March 07, 2012, 11:37:37 am »
so if I went for even lower KV motors and 6S then I could probably get away with even lower capacity cells?
he reason I ask is I have some 3000mah 6S lipos from my 500 heli :)
Subculture
« Reply #3 on: March 07, 2012, 01:14:03 pm »
Yep. The controllers tend to get more expensive for those higher voltages though.
Page created in 0.376 seconds with 21 queries.
