Author Topic: Red Cross decals...  (Read 7966 times)
U-33
  • K-157 Vepr. Akula-11
Red Cross decals...
« on: March 23, 2012, 11:34:11 am »
Anyone got any ideas as to where I may be able to buy a set of Red Cross vinyl/waterslide/whatever/ decals as used on hospital ships?
I'm going to build my QM2 as she would look if ever she were called up for hospital ship duties, something like the ship in the pic below.
Re: Red Cross decals...
« Reply #1 on: March 23, 2012, 11:42:51 am »
Could you try Red insulation tape ?
6705russell
« Reply #2 on: March 23, 2012, 11:46:45 am »
Hi Rich
I would get a piece of red vinly from a local signwriters and cut them out to required size...
Russ
U-33
« Reply #3 on: March 23, 2012, 11:48:13 am »
I'd thought of that Ken...but it didn't look sort of 'right'. Know what I mean? There's always a hump where the two pieces go over one another. Unless I make them up out of individual pieces on a separate base...
U-33
« Reply #4 on: March 23, 2012, 11:49:49 am »
Hi Rich
Russ
That's another way of doing it Russ...I'll ask Nige(Caddick), he's the man for that sort of thing.
6705russell
« Reply #5 on: March 23, 2012, 11:52:18 am »
If you draw the outline you can sharp-blade them out then...
Russ
« Reply #6 on: March 23, 2012, 12:08:14 pm »
Red coach lining and make each cross with 3 pieces of coach lining.
U-33
« Reply #7 on: March 23, 2012, 12:14:31 pm »
3 pieces? Go on...
« Reply #8 on: March 23, 2012, 12:18:11 pm »
Not rocket science Rich.
One length right through either vertical or horizontal and two short bits butted up to the long bit to form the cross.
That way no overlap.
« Reply #9 on: March 23, 2012, 12:19:15 pm »
U-33
« Reply #10 on: March 23, 2012, 12:22:48 pm »
I knew that...I was just checking that you were on the same wavelength as me.   %)
Cheers Dicky..
CJ
« Reply #11 on: March 23, 2012, 01:53:31 pm »
Rich,
For the red cross on my RML http://www.modelboatmayhem.co.uk/forum/index.php?topic=35249.0 I used self adhesive vinyl from these guys,as below...
http://www.ebay.co.uk/itm/Self-Adhesive-Vinyl-Coloured-Stickers-Sheets-Roll-Sign-Set-Sticky-Back-Plastic/110755262819?ssPageName=WDVW&rd=1&ih=001&category=46742&cmd=ViewItem
It comes in sheets so you can have a few tries 1st, just draw out and cut with a sharp blade - waterproof and even varnished over the top with no reaction at all so highly recommended.
Basically same as what Russ said  :embarrassed:
CJ
"Blessed is he who, in the name of charity and good will, shepherds the weak through the valley of the darkness"
U-33
« Reply #12 on: March 23, 2012, 02:47:49 pm »
That looks good to me CJ, just ordered a sheet of that to play with.
Many thanks,
CJ
« Reply #13 on: March 29, 2012, 10:34:42 am »
Good Luck Rich,
Hope it works out OK.
CJ
emlra
« Reply #14 on: April 01, 2012, 05:23:33 pm »
BW Models (1/72 scale white Metal vehicle specialists) do decals for their Ambulance models
Depending on the dimensions required, they may be worth a look;
Rex
Yer Tiz!
slug
« Reply #15 on: April 02, 2012, 07:16:55 am »
you may find that local signwriting firms will be able to cut them out for you a firm near me cuts cutsl letters down to 5mm as long as its on the cutter program they do it slug
U-33
« Reply #16 on: April 02, 2012, 11:51:48 am »
CJ's link was ideal, the material was perfect, and dead easy to use....I've ordered a few more sheets to play with for the decals on my new Spearfish.
Thanks all,
CJ
« Reply #17 on: April 02, 2012, 01:10:06 pm »
Glad it worked out OK Rich !!  :D
CJ
Page created in 0.031 seconds with 22 queries.
