Author Topic: Help wanted with battery power  (Read 2184 times)
wullie/mk2
« on: April 12, 2012, 02:38:07 pm »
Hi guys, i,m needing some help with my Schnellboot, I have 3 x 7.2 motors fitted, and have 2 x 30amp Electronize speed contr, I have the port/starboard motors running off one contr, and the centre off the other,the Batteries i have are 2 x 3600mah 7.2v,...the boat did have 3 x speed controller with 3 x seperate batts, but one speed contr, was not working,hence the new set up, what I need to know is how to I get longer running time,as i feel that only having 1 x 7.2v batt for 2 of the motors and the other motor has 1 x batt,the drain on the batt that serves the 2 motors will be huge,
Wullie,s place is an apology free zone
andrewh
Re: Help wanted with battery power
« Reply #1 on: April 12, 2012, 03:37:45 pm »
Wullie
I know its a Schnellboot, but Hailwood's saying always works:
"The Throttle goes both ways"
You could parallel the 2 packs, so that all three motors draw from the 7.2V 7200mah pack
andrew
« Reply #2 on: April 12, 2012, 04:19:52 pm »
You could parallel but the way you are at the moment you have a recovery mode if the two outer motors
have used all their run time , a single screw will get you home.
wullie/mk2
« Reply #3 on: April 13, 2012, 11:06:34 am »
Hi guys,thanks for the help,
as it stands just now, I have the 2 x motors running off the left stick,and the centre motor off the right stick,with the rudder on the right stick,L/R...then the centre stops when i turn L/R, which is fine for me,at the moment,
I only use 2 x motors for normal sailing, and all 3 for a quick burst,
As for my choice of Batteries,
Could I get away with using 1 x 9.6v 4500mah battery to power the port/starboard motors,..and 1 x 8.4v 4500mah to power the centre motor,
btw the boat is a 1/25th scale
furthermore, I,d like to fit a mixer,so that when I,m turning L/R ..the motors are giving me the best combination of power,..1st, of all, would a V,Tail mixer suffice,?????
wullie/mk2
« Reply #4 on: April 13, 2012, 11:14:38 am »
As a another matter, of interest, the motors in the boat are 3 x Graupner 600FG 7.2 ,s,with a 3.1 ratio gearbox,..they are listed on the GrauPner website as aero motors,, will these be ok, the props are 55mn brass ,Witches Hat type,..long pointy boss,
Page created in 0.53 seconds with 22 queries.
