Author Topic: Sea Bex One  (Read 3627 times)
Tim
Sea Bex One
« on: May 07, 2012, 05:32:44 pm »
Hi my name is Bill
 I found your forum very helpfull .
 I found A Seabex One model that has been in dry dock for many years and the wiring is in very bad shape.
 When looking for help i found this wiring diagram on Daves World . I need help with  Y branch marked in red
 i do not want to smoke it.
        thanks    Bill
oldiron
Re: Sea Bex One
« Reply #1 on: May 08, 2012, 03:58:52 am »
Is this how your Seabex is wired?
cos918
Re: Sea Bex One
« Reply #2 on: May 08, 2012, 05:55:18 am »
Hi Bill
I am with John on this. This wiring digram is only good if Graupner equipment is used. You need to check  what make of equipment is being used. Photos speak words
john
Tim
Re: Sea Bex One
« Reply #3 on: May 08, 2012, 09:09:43 pm »
 Hi John and friend
 one of the nautic 2-16 is burnt and i hope i can get by with one. I mest up my first replay      Bill
cos918
Re: Sea Bex One
« Reply #4 on: May 09, 2012, 05:43:02 am »
Hi Bill
There are a few minor diferance in both wiring digrams. which one are you using?
john
Tim
Re: Sea Bex One
« Reply #5 on: May 09, 2012, 05:36:48 pm »
 Hi John
 The boat was set up to use 2  nautic experts . I only have 1 good 1left . I would like to use the one from Daves World . could you draw me a sketch of
 the wiring for the Y set up in color, the part in the red square i do not want to burn the only one i have they cost $150.00 each
        Thanks Bill
cos918
Re: Sea Bex One
« Reply #6 on: May 09, 2012, 06:48:46 pm »
Hi Bill
I have used the Robbe F14 equipment which is similar to the Grauppner stuff put there are diffreances.  I would email Daves world as he as modiffied that wiring digram. Looking at both digrams on the orgnial the crane switching units have 2 input one for each direction so X 6 input req for the crane. Since the helicopter + water pumps run 1 way only they only need 1 input. that make 8 input and your decoder unit has 8 outputs.  I not sure on this but email grauppner and they shoul be abel to help.
john
Tim
Re: Sea Bex One
« Reply #7 on: May 10, 2012, 04:02:52 am »
 Thanks For the help John i will try graupner Bill
Page created in 0.385 seconds with 22 queries.
