Hello all! I've spent the last couple of weeks building a diy vacuum former in order to scrtch build some vents so here is a short description of how i did it and some results.
The vacuum former was made from melamine which is plastic coated chipboard that fitted kitchens or wardrobes are built from. To create a good seal i assembled the box with household silicone bath sealant which i applied along the joints in a continuous bead like you would PVA wood glue. The frame for the plastic sheet is an old A5 picture frame that i strengthened with two strips of hardwood. I used double sided foam tape to fix the plastic sheet to the frame then placed a second frame over the sheet when under the grill. I found this didn't need clamping down to stop the edges of the plastic sheet from curling up+allowed for quick removal prior to vacuum forming. The white strip around the bed of the box is household sticky backed rubber draft excluder strip, this creates a great airtight seal when the frame and plastic sheet is placed over it. The holes in the bed are approximately 20mm apart.
The patterns for the vents were made from model board. On the first run the plastic kept forming into ridges around the base of the vents due to their shape. To overcome this i lengthened the patterns so that i could simply cut the base away to leave the top of the mold which wasn't effected.
The ridges can be seen in this photo.
Excess plastic removed leaving the base and vent.
The assembled vent with additional detail which includes a grab rail which runs around the back of the vent and i assume was used for rotating it.
This vent was made using the same pattern as the first but has a lengthened flue and sits directly behind the forecastle.
This vent required a different pattern for its base and top. It sits just behind the forward torpedo tube and has a squashed opening to allow the torpedo tube to pass under it without fouling.
I've included this photo to show the difference between the size and shape of the vents when made to scale next to one included with the kit.
