Author Topic: Water exhausts  (Read 3850 times)
PJ
Water exhausts
« on: June 07, 2012, 01:45:03 pm »
Can anyone suggest a way to simulate the exhaust cooling water coming  form the engines. Can do it with a pump but that just provides a constant stream of water. What I'm after is a pulsed stream of water. Any ideas suggestions?
CJ
Re: Water exhausts
« Reply #1 on: June 07, 2012, 02:57:47 pm »
If on a pump can you not just "pulse" the voltage to what you require ?
Even a simple timer relay would give you a few options with and "on" and "off" time ?
CJ
"Blessed is he who, in the name of charity and good will, shepherds the weak through the valley of the darkness"
6705russell
Re: Water exhausts
« Reply #2 on: June 07, 2012, 03:39:47 pm »
I used a pulse output unit from Maplins, you can set the time delay between each pulse so it simulates a bilge pump quite good..
Russ
boneash
  • In an actual war zone there are 2 types of ships,
Re: Water exhausts
« Reply #3 on: June 07, 2012, 03:48:52 pm »
Hi
On a 'real' boat marine engine there is a continuously running pump, the pulse of the water in the exhaust is probably due to the volume of space in the 'water lock'.
 http://www.vetus-shop.com/vetus-waterlock-muffler-nlp75-75mm-p-595.htm
lThis is not just a silencer but a place where the water can be collected when the engine stops to prevent it running back to the cylinder head.
A small container with an output higher than the input should be able to replicate the pulsing effect.
good luck
Rottweiler
6705russell
Re: Water exhausts
« Reply #5 on: June 07, 2012, 09:25:23 pm »
No not that one Mick,  I will have a look for a link....
Russ
PJ
Re: Water exhausts
« Reply #6 on: June 07, 2012, 09:31:00 pm »
Wow - Great responce and quick. Thanks for the ideas
6705russell
Re: Water exhausts
« Reply #7 on: June 07, 2012, 09:34:33 pm »
For some reason I can't copy the link, the unit is a Mk111 Adjustable timer with relay output Maplin order code -VT27E
Russ
PJ
Re: Water exhausts
« Reply #8 on: June 07, 2012, 09:42:05 pm »
Look like I could use it to generate a flashing ligt as well!
Thanks Guys
Phil
Rottweiler
Re: Water exhausts
« Reply #9 on: June 07, 2012, 09:56:49 pm »
Thanks Russ, will go have a looksee.
Mick F
gribeauval
Re: Water exhausts
« Reply #10 on: June 07, 2012, 10:46:20 pm »
Russ
You mean this link Russ !!
                                                   http://www.maplin.co.uk/mk111-adjustable-timer-with-relay-output-25224
True Lifeboat Nutter!!
Rottweiler
Re: Water exhausts
« Reply #11 on: June 07, 2012, 11:27:48 pm »
Hi Mike,
yeh thats the one I just looked at,seems good and cheap too!
Mick F
roycv
Re: Water exhausts
« Reply #12 on: June 08, 2012, 08:22:49 am »
I used to run a copy model of Streamlinia and she was steam powered.  The water pick up for the boiler was a small "scoop" aft of the propeller.  There was a water outlet an inch or so above the waterline.  When I converted to electric I just connected the inlet to the outlet with  neoprene tubing to avoid removing anything.
This surprisingly gives a slightly intermittent water flow.  Might suit and has no working parts.
regards Roy
Page created in 0.625 seconds with 21 queries.
