Author Topic: Gaurd rails Fairmount Alpine  (Read 3812 times)
david48
« on: June 23, 2012, 11:18:22 am »
I have put the handrail together for my build ,useing the supplied wire in the kit ,useing the smallest brass wire supplied, to discover there is not enough I then ordered some .5mm brass wire from 4D modelshop.co.uk, when it arrived I checked the size againest the one in the kit to discover that the wire in the kit was bigger ,it is .75mm not .5mm the build manual  says item F22A is .5mm dia .So the upshot is I should have miked all the wire first and not assumed that the smallest wire was .5mm .I will now have to source some new stanchions. Any one Building this kit might want to check better than I did.
A71
Re: Gaurd rails Fairmount Alpine
« Reply #1 on: June 25, 2012, 09:51:04 pm »
Have you contacted the company who makes the kit ? They might (should ) be able to help
Ps forgive my noob ness as I'm not sure who makes the kit
irishcarguy
« Reply #2 on: June 26, 2012, 07:55:08 am »
Hi A71, Billings make the kit which I have & when time permits I will measure the railing wire in my kit & post the results. Mick B.
Mick B.
« Reply #3 on: June 26, 2012, 09:34:10 am »
Billing boats I think.... not one for replying to emails
awvs
« Reply #4 on: July 17, 2012, 04:46:51 pm »
Hi David,
I didn't use the brass wire supplied with the kit, instead I bought .7mm brass rods and it worked great. By the way, there were not enough stanchions in the kit. I did contact the Billing representative in British Columbia and he promised that he would ship the missing parts. I am waiting now for more than two month. In the meantime I bought the stanchions on ebay.
By the way, I did use .5mm styrene for the extra steel plates along the hull.
Wilhelm
Page created in 0.352 seconds with 21 queries.
