Author Topic: Calculating rudder size?  (Read 3344 times)
XV Pilot
« on: July 10, 2012, 08:38:07 pm »
Hello.
The title says it all really. How do I go about working out the right size for my rudder?
The boat in question is a knock-off of the Graupner B-24 "Bat Boat" which  measures 655mm by 235mm, and will be (under)powered by a pair of 380-size motirs of dubious origin.
The rudder recommended by Graupner for their model is the G2322, but I don't see how I am meant to mount that to the transom and still have space for the servo horn to move without cutting a big hole in the transom for it.
I would prefer to use something like the G2332 which looks like it will stick out far enough to leave space for me to run a pushrod to the horn through a small bellows-sealed hole in the transom, but the sizes are confusing me a bit.
These are the rudders I am considering: http://www.cornwallmodelboats.co.uk/acatalog/race-rudders.html
Thanks!
Re: Calculating rudder size?
« Reply #1 on: July 11, 2012, 07:12:04 am »
Manfjourde
« Reply #2 on: July 21, 2012, 05:07:37 am »
I kind of have the same question. I have a Sea Nymph and Commander and Swordsman on the way. Any recommendations on rudders for those and where is the best place to get them in the US?
HS93 (RIP)
  • I cannot spell , tough
« Reply #3 on: July 21, 2012, 07:33:07 am »
http://www.cornwallmodelboats.co.uk/acatalog/boat_rudders.html
I would use the mini 40x26 on the Nymph
and the medium or large depending on how fast you are going if fast go for the smaller   55x36 or 60 x 41 on the commander remember if you get the larger you can cut them down with snips or a Junior hacksaw
the medium on the Swordsman 55x36 as that will be going quicker, again you may have to trim a small amount off the front edge to aid fast sailing
keep them nice and light and they will perform great, I have built all the originals many years ago and these where the type of rudder suplied by model shops at the time, (but with brass outer tubes)
Peter
surfs up
« Reply #4 on: July 21, 2012, 01:04:28 pm »
I would forget rudders and use a mixer and two esc.
Manfjourde
« Reply #5 on: July 21, 2012, 04:55:10 pm »
Peter, thanks for the info and link!
