Author Topic: Propshaft tube fixing  (Read 2687 times)
Nordlys
« on: July 11, 2012, 08:53:12 pm »
Can anyone recommend a suitable /preferred adhesive for securing a new propshaft tube into
the hull.
Had to remove mine today after sailing, as it had actually split lengthways down
half the length of the tube
Thanks....
Nordlys
boatmadman
Re: Propshaft tube fixing
« Reply #1 on: July 11, 2012, 09:13:49 pm »
Secure the shaft in place, on the outside, put insulating tape over the hole and around the shaft. Use P40 to build up around the shaft on the inside of the hull. Once dry, take off the tape on the outside and fill any gaps with P38, sand and paint - job done!
P38 and P40 both available at a well known high street motor spares outlet!
Ian
Andyn
« Reply #2 on: July 11, 2012, 09:18:19 pm »
Firstly though, replace the tube with a proper piece of extruded brass, not cheap rolled stuff :-))
Nordlys
« Reply #3 on: July 11, 2012, 09:30:31 pm »
Aah! Interesting? How would I tell the difference?
I generally buy the tube and shaft as one unit from Ebay or model shop
Thanks.
Nordlys
« Reply #4 on: July 11, 2012, 09:32:33 pm »
Ian,
Can you enlighten me on the difference between P38 & P40 please
- I know the shop you refer to begins with an H!
Thank you....
« Reply #6 on: July 11, 2012, 09:37:31 pm »
Page created in 0.036 seconds with 22 queries.
