Author Topic: Atomatic boiler control  (Read 4153 times)
Ian Robins
« on: April 21, 2007, 03:15:03 pm »
Hi All
I have the drawings of various electronic circuits to control boiler water levels.
But I do not want to fit a water sensor into the boiler as per M beak's.
I am looking for the details to give the require reading via the boiler sight glass.
Any ideas.
Martin: this cold also be a electronics topic
ro88o
HS93 (RIP)
  • I cannot spell , tough
Re: Atomatic boiler control
« Reply #1 on: April 21, 2007, 09:18:53 pm »
have you seen how the cheddar one worked, it shone an led and had a receiver led on the other side, when the beam passed through the glass(no water) it moved the servo.
Peter
Ian Robins
« Reply #2 on: April 22, 2007, 08:30:13 am »
hi hs93,
Thats great all i need is a on/off circuit from the led and the M beak's circuit with a pump will work.
I will have a look at RS and Maplins
ro88o
malcolmbeak
« Reply #3 on: April 22, 2007, 08:49:10 am »
ro88o
A word of warning - the original article as published had an error in the component diagram and I think in the circuit diagram. Not our fault I hasten to add! The article with these errors corrected are available as a download from the paddleducks site. Hope this is of use to you.
Malcolm
Ian Robins
« Reply #4 on: April 22, 2007, 09:03:59 am »
Hi Malcolm,
Thanks for the info. Are you coming to the Mayhem Weekend as I would be good to have a chat.
Have you used a water guage for water level control
ro88o
malcolmbeak
« Reply #5 on: April 22, 2007, 09:18:01 am »
Hi ro88o
Afraid I can't make it to the mayhem do.
I use an internal probe in the boiler rather than a fitting on the water gauge. As I make all my own plant, it's easy to incorporate the probe during the build. I have one steam plant (not in a boat at present) that has a Scott boiler (not Scotch) that is only one and an eighth inch diameter  and about six long. No room for a gauge glass. With no feed it lasts less than 5 minutes, but using the level control and an engine driven pump it has run for well over half an hour so things must be working OK.
If you want a chat, PM me and I'll let you have my phone number.
Malcolm
DougMaz
« Reply #6 on: April 22, 2007, 12:54:16 pm »
Hi Malcolm,Any Chance of a drawing or photo of your Automatic boiler control Thanks. Dougmaz
DougMaz
malcolmbeak
« Reply #7 on: April 22, 2007, 06:22:12 pm »
Hi Doug
Nothing to show in a photo - a probe on a boiler and a box of electronics.
Go to http://www.paddleducks.co.uk/ then go to downloads / steam engine articles / Malcolm Beak. You will find several articles about water level control, gas control, an engine and gearbox designs.
Is this OK?
Malcolm
Bernhard
« Reply #8 on: February 23, 2008, 08:48:55 am »
hi
i use this in my Lady Jane...work ok....
http://www.home.earthlink.net/~bfindus/index.html
regards Bernhard
