Author Topic: Solder types and temp  (Read 4405 times)
« on: August 05, 2012, 08:07:50 pm »
I'm only used to electronic type soldering .... done a bit of low temp brazing but that's abut it.
I need to have another go at soldering ship railings (groan!), what options do I have for soldering?
(Railing will be brass stations or all steel.)
chipchase
Re: Solder types and temp
« Reply #1 on: August 05, 2012, 08:37:48 pm »
Hi Martin, I always silver solder my brass stantions. I have found 0.5 silver solder is ideal for rails. Here is a link to the company that I get all of my silver solder from, I have used this company for about two years and I cannot fault there service. :-))
http://www.cupalloys.co.uk/
Brian
pettyofficernick
  • Marineville will be destroyed, Muahahaha.....
« Reply #2 on: August 05, 2012, 08:43:14 pm »
Brian
I totally agree, brilliant company which will supply small amounts of silver solder, flux etc, how to pages and they even do a small brazing hearth for about 35 quid, and postage is free to boot. :-)) :-)) :-))
What I do is best not discussed, for I have been many things in my time....
« Reply #3 on: August 05, 2012, 08:50:22 pm »
http://www.cupalloys.co.uk/  as Brian says Martin.
They also do the old lead, low heat  solder still.
Re: Soilder types and temp
« Reply #4 on: August 05, 2012, 08:51:30 pm »
Check their silver solder paste in a syringe, better than chasing pallions (look it up) and dobs of flux about.
  Regards Ian.
 Don't soft solder first and then decide you should have silver or hard soldered.
chipchase
« Reply #5 on: August 05, 2012, 09:07:37 pm »
  Regards Ian.
Haven’t tried silver solder paste before, will buy some on next order cheers Circlip
« Reply #6 on: August 08, 2012, 08:13:05 pm »
I recently watched some silver soldering being done - having seen that I'm not scared to try it now.
« Reply #7 on: August 09, 2012, 07:32:56 am »
  Regards Ian.
Just to confirm...
I just add a blob of the paste to the joint to be soldered and then heat it untill the solder flows and makes the joint?
Page created in 0.188 seconds with 22 queries.
