Author Topic: which engine  (Read 3421 times)
Peewee
    • Paddleducks
which engine
« on: August 16, 2012, 03:02:47 pm »
Hi All.
I am in the process of building a lifeboat, finished research on my steam powered waverley should restart building shortly and am therefore starting to think about the next project in line.
would anyone have a recomendation of an engine that would power a 60" trawler hull.  i dont mind what type of engine, kit or castings to machine.
cheers
Ian
Ian
Still sane? who knows who cares?
boatmadman
Re: which engine
« Reply #1 on: August 16, 2012, 03:49:04 pm »
How a bout a nice twin piston valve engine machined completely fro bar stock?
Like these:
I can point you to the plans if you wish, they are free and contain a wealth of machining tips.
Ian
Peewee
    • Paddleducks
Re: which engine
« Reply #2 on: August 16, 2012, 03:56:00 pm »
they look great little engines and i like the idea of barstock   O0
Ian
HS93 (RIP)
  • I cannot spell , tough
Re: which engine
« Reply #3 on: August 16, 2012, 04:37:31 pm »
is that A nice pair of Boggies I see ? you have done the plans Justice
I think Pee Wee has an original paddle engine of his.
Peter
boatmadman
Re: which engine
« Reply #4 on: August 16, 2012, 04:38:01 pm »
Here is a link:
http://www.machinistblog.com/bogstandards-paddleduck-engine-plans/
If you log into HMEM there are build logs and lots of info and tips available as well:
http://www.homemodelenginemachinist.com/
You will need a mill as well as a lathe, although having said that, you may be able to do it all on a lathe if you have milling gear for it.
I only have small stuff, taig (peatol) lathe and seig x2 mill, but both these managed all the machining with capacity to spare.
Good luck, and pics are required.
If you think I can help, get in touch., although the deisigner, John Moore aka Bogstandard is very approachable and helpful.
Peter, yes they are a pair of Boggies and were the first major engine build I attempted.
Ian
HS93 (RIP)
Re: which engine
« Reply #5 on: August 16, 2012, 04:42:56 pm »
Ian have you joined Johns (Boggie's) new site yet ?
Peter
http://www.modelenginemaker.com/index.php
boatmadman
Re: which engine
« Reply #6 on: August 16, 2012, 04:44:25 pm »
No, didnt know about it, thanks, will go join now.
Ian
boatmadman
Re: which engine
« Reply #7 on: August 16, 2012, 05:04:08 pm »
Pewee,
A change of direction, go to the Site posted by HS93, its more up to date and is administered by the man himself.
Ian
Peewee
    • Paddleducks
Re: which engine
« Reply #8 on: August 16, 2012, 07:09:23 pm »
thank you all for the info, i do indeed have his original paddle engine which is set for the Waverley  build here http://www.paddleducks.co.uk/smf/index.php?topic=5594.0
I will have to join his site, i was not aware he had set one up.
cheers
Ian
Ian
Page created in 0.017 seconds with 21 queries.
