Thanks dodgy geezer, just a few questions as I have no idea whatsoever
What do you suggest and what does I/C mean
2 decide if you want to stay with the I/C power unit or go electric. Modern electrics are quite powerful, and a lot of lakes don't let you use I/C, so you might prefer to change the power unit...
I this the correct unit? and what does ESC mean
3 - get a new 2.4Ghz radio with servos from Giant Shark. If you wanted to change power units, get a motor,
http://www.giantshark.co.uk/giantcod-24ghz-4channel-mode2-transmitter-p-403779.htm latteries and an ESC at the same time.
No problems! I just put down some stages you'll probably go through - you will have lots of questions about each of those stages, I'm sure...
I/C - internal combustion. The motor you have is an 'internal combustion' type. Car petrol engines, diesel engines and glow-plugs are all this type - you have a 'glow-plug'. Glow plugs work off buying glow-plug fuel (I see you haven't got a fuel tank on that boat - you'll need to get one, probably mount it next to the engine near the bow, and attach a fuel lead to that little connector on the carburettor). Then you attach a 1.5v, high amp battery to that little plug on top of the motor with a special connector, and turn the brass flywheel around with a cord in the groove. Once it's going, you can remove the glow-plug connector, and the motor will keep going until the fuel runs out. I suspect you might find electric easier to operate, but that would mean modifying the motor mount and buying a new electric motor...
ESC - electronic speed controller. If you were to use an electric motor, you control the motor speed with a special box called an ESC. It plugs into the receiver like a servo, but has extra leads connected to the battery and the motor. You only need this with an electric motor...
You probably need to know a bit about radio control boxes. You typically buy a Transmitter/Receiver combination (Tx/RX Combo) and then buy servos or escs as you want.
There are various frequencies available on the market.
27Mhz - Ok for all models, but a lot of toys use this frequency so there can be interference
35Mhz - only for aeroplanes
40Mhz - only for boats/cars - the sets can be a bit expensive, but there are often second-hand ones available, because lots of people are switching to:
2.4Ghz - this is a new frequency - the sets can be very cheap, there are no problems with interference and there are other reasons why they are particularly easy to use. I'd recommend that you got one of these. The Planet T5 (about £45) and the Radiolink T4U (about £25) are commonly used...
