Pages: 1 [2] 3 4 5 6 7 8   Go Down
Author Topic: Handmade steam engines.... on a budget  (Read 53683 times)
Mad_Mike
  • Lincolnshire
Re: Handmade steam engines.... on a budget
« Reply #25 on: October 25, 2012, 09:51:30 am »
good idea that. Im afraid i dont know ANYONE with a pillar drill though. Im doing allright for the minute they are not perfect but theyre close. Ill have a go at the beam engine trusting i have the materials of course. Im not sure that it will warranty a watts linkage because the engine i build wont be that exotic. well see.
« Reply #26 on: October 25, 2012, 10:15:32 am »
Im sure there's someone on here that can do them for you.... Failing that let me know and I knock you some up from a bit o'scrap next time I'm in the Workshop
Mad_Mike
  • Lincolnshire
« Reply #27 on: October 25, 2012, 10:23:35 am »
yes there are  a lot of helpful people of here. Im not worried thanks for the offer to make me some up aswell, ill get in touch if i need you.  :-))
frazer heslop
« Reply #28 on: October 25, 2012, 03:45:55 pm »
Mike, have a look on the john_tom site I think there are some of Elmers simple beam and other engines on there
kind regards
frazer
steamboatmodel
« Reply #29 on: October 26, 2012, 04:20:02 am »
Hi Mike,
I have a list of books on RC Groups that may be help.
http://www.rcgroups.com/forums/showthread.php?t=1226384
I don't still have it but my first steam engine was built using a small drill press and hand tools. I did have some drill guides mad by a friend of my dads, but I had to draw them out and he produced exactly what I had drawn and I had to pay for material. I have also seen a couple of engines made with hobby store K&S brass tube, as you can get tube that nests inside each other.
http://www.ksmetals.com/
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
Mad_Mike
  • Lincolnshire
« Reply #30 on: October 26, 2012, 08:32:52 am »
thanks very much for the links. Ive seen that k n harris link before but couldnt remember what it was called or where i found it. I found that although the k s tubing does fit inside each other that they are still slightly baggy, they make good bushes but not great pistons and cylinders. I found that a 9/32 brass bar fits perfectly tight in a 8mm  ks tube. the ks tube having an internal diameter of 7.1mm and the 9/32 having an outside diameter of 7.14 thus i only need to rub down with wet and dry the surface of the 9/32 to get a good fit. Another than fits aswell is a 12mm bar in a 1/2 inch k s tube, also just needing a slight rubbing down.
grasshopper
    • A1 Hobbies Ltd.
« Reply #31 on: October 26, 2012, 10:13:25 am »
Mike, your address is listed as Lincolnshire.....where in Linc's, it's a big county?
If you're not living completely out in the boonies - there must be someone nearby that has stuff you could beg, borrow or access to help things along.....is there not a college you could sign up an engineering course for and use their equipment or even a local engineering works that would let you have access for the cost of a pint?
Great work by the way - especially on your limited equipment basis, you're becoming our British Krishna......
Mad_Mike
  • Lincolnshire
« Reply #32 on: October 26, 2012, 10:25:03 am »
im in scunthorpe to be more precise but there seems to very little help with anything round here. Signing up for a college course is not necessary ive allready been. Plus they dont let just anyone in to use the equipment. Theyre maybe smaller companies who might let me have a go on their gear but with the majority of the smaller firms going bust and only the larger health and safety strict companies left i wont get past the reception. Its all about liability see.
Mad_Mike
  • Lincolnshire
« Reply #33 on: October 26, 2012, 10:48:26 am »
Anyway part of my main aim of this thread is show that live steam can be done without the use of pillar drills, mills and lathes and to show that you dont need to spend silly money to enjoy steam either. Im using basic hand tools such as files, hack saw, battery drill and bits all available from your local wilko, a table clamp vice to the hold job in of course. There are some more specialist tools ive needed granted such as a tap and die set. Overall if i did venture into more exotic machine tooling id be drifiting to far away from the point and then it would be just another workshop steam engine building blog. I hope that people reading this will use it as an example and take the opportunity to have a go in a area of moddling usually out of most peoples reach.  :-))
pettyofficernick
« Reply #34 on: October 26, 2012, 11:30:00 am »
Tap and die set, only 25 quid including post, I have one and it has served me well for several years now.....
http://www.chronos.ltd.uk/acatalog/info_MXP33_.html
ooyah/2
« Reply #35 on: October 26, 2012, 11:37:53 am »
Good for you Mike just keep at it remember the saying ( every day in every way things will get better and better ) .
Some day you may invest in a pillar drill, B& Q used to do them for about £40 , don't know if they are still available if so a well worth investment when you have the funds and it will not take you away from your basic idea.
George.
Mad_Mike
  • Lincolnshire
« Reply #36 on: October 26, 2012, 07:06:09 pm »
where i am at the moment i dont have the room lol
grendel
« Reply #37 on: October 26, 2012, 10:16:09 pm »
somewhere I have a drill pillar for my dremel type drill, I really must dig it out and see if my drill still fits it ( I am about 3 drills down the line from that one) but you can get them for small stuff
, its only about 10" high
Grendel
grendel
Mad_Mike
  • Lincolnshire
« Reply #39 on: October 27, 2012, 10:13:40 am »
i was gonna place a bid but there no gurantee thatl it fit the drill i have.
grendel
« Reply #40 on: October 27, 2012, 10:18:46 am »
same here, my drill isnt a dremel (its a cheaper one from maplins) so no guarantee, but then I already have a small drill stand that I have to find and see if any of my (several) drills fit.
Grendel
Mad_Mike
  • Lincolnshire
« Reply #41 on: October 28, 2012, 09:42:11 pm »
Well I said i fancied building a beam engine if i had the bits and guess what i had the bits so thats exactly what i did. The engine is single acting with a 12mm bore and 20mm stroke. The valve is a rotary type similar to that in corliss engines. The flywheel is a pile of washers connected to the crankshaft by a rc aeroplane propeller adapter. I have some youtube footage on the way
Mad_Mike
  • Lincolnshire
« Reply #42 on: October 28, 2012, 09:43:28 pm »
here is the flywheel and here is the youtube video
http://www.youtube.com/watch?v=5wkjKkvqsc4&feature=plcp
pettyofficernick
« Reply #43 on: October 28, 2012, 11:14:52 pm »
Brilliant! What's  next? :-)) :-)) :-)) :-))
richald
  • Retired and loving it!
« Reply #44 on: October 28, 2012, 11:20:46 pm »
Fantastic !
Richard
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
boatmadman
« Reply #45 on: October 29, 2012, 09:07:20 am »
Very well done, you should think about posting on these sites:
http://madmodder.net/index.php
http://www.modelenginemaker.com/index.php
Its just the sort of thing they love to see.
Mad_Mike
  • Lincolnshire
« Reply #46 on: October 29, 2012, 09:23:58 am »
lol whats next, isnt that enough?!  %% {-)  Im suprised you arnt all sick of seeing steam engines. Im contemplating a 4 stroke ic engine but i need some extra bits that i dont have right now. I doubt it will work and i guess that the solder what hang on for long but its worth a try.
Mad_Mike
  • Lincolnshire
« Reply #47 on: October 29, 2012, 09:32:44 am »
I suppose i could but i was building a marine engine for my new up and coming tugboat project. Anyway i like this forum ;D
pettyofficernick
« Reply #48 on: October 29, 2012, 09:35:38 am »
Hi Mike, Hmm, a 4 stroke engine, valves, camshaft, carburetor, sounds like fun. Here's a couple of links to possibly inspire you..
First a hit and miss engine,
http://videos.howstuffworks.com/howstuffworks/183-how-hit-and-miss-engines-work-video.htm
Ans second, a flame gulper vacuum engine, bout simpler in construction to a full blown 4 stroke
http://www.youtube.com/watch?v=7p_1QO1iG9M&feature=related
« Reply #49 on: October 29, 2012, 09:51:31 am »
Quite the opposite.... when I look at the unread post since last visit and this has an update, it's the first one I look at
Pages: 1 [2] 3 4 5 6 7 8   Go Up
