Author Topic: Breathing life into an old controller aka Pimp my TX  (Read 3673 times)
« on: October 01, 2012, 07:10:32 am »
I'm not sure where to put this or if anyone is even interested, but over the weekend I had a bit of fun with my stepdaughters transmitter.
She's into RC cars and boats and has a Robbe Katja and a short course truck.  Both use the same old "hand me down" TX that I think I have owned since the mid 80's.
So while she was away at her dads for the weekend I had a plan.....
I carefully removed all the electrics and cleaned th case.  As I said the unit is years old and looking a little sorry for itself.
Next we masked up the black area as I wanted to keep this as it is
Off to the paints box and a quick experiment with some tamiya polycarbonate spray I had left over from painting her Katja.  Its stuck to the case very well and gave a nice durable finish
Yes its pink! very pink!
Have to say it looks so much better with the new paint job.  I have since sprayed the case with a couple of coatts of automotive clearcoat
Next will be the addition of a little bit 'o' bling (some stick on Gemstones)
If anyone is interested then I'll post up more pics when its complete.
On a side note does anyone know of any company that does a 2Ch 2.4Ghz traditional twin stick TX?
Re: Breathing life into an old controller aka Pimp my TX
« Reply #1 on: October 01, 2012, 07:56:42 am »
the femine side of us comes out in the strangest of places {-) {-) {-) {-) {-) {-) {-) :embarrassed: :embarrassed: :embarrassed: :embarrassed: :embarrassed:
« Reply #2 on: October 01, 2012, 08:27:39 am »
LOL yep... was one of those "Hmmmm I wonder if..." moments
« Reply #3 on: October 01, 2012, 09:25:57 am »
Acoms do a 2 Chann Twin Stick.
« Reply #4 on: October 01, 2012, 09:52:01 am »
Yes I had seen that one, but having had Acoms 2.4 (Acoms Hyabussa) in the past 2 things put me off
1 the price of the Receivers (and there are no compatible clones)
2 The Acoms 2.4G system is not very good.  There are a lot of stories of binding issues and a high failure rate of receivers (which I can back up with my own experience)
I have to say having used acoms stuff in the past (through the 80s and 90's) I was quite suprised about the issues I had with the 2.4
w3bby
« Reply #5 on: October 01, 2012, 10:08:24 am »
With the price of the 4 (and more) channel offerings such as this I wouldn't bother looking for just 2. You don't have to use all the channels :}
« Reply #6 on: October 01, 2012, 01:24:52 pm »
Interesting!
 Can you expand on cleaning the surfaces and what you used to prep them for painting please?
 Martin
« Reply #7 on: October 01, 2012, 06:35:07 pm »
Interesting!
 Martin
after stripping the unit down I rubbed down the areas with chips and scratches with old 1000 grit wet and dry used wet.
Next I cleaned it down in soapy water...  Use the cheap stuff, not the ones endorsed by Nanette Newman et all, rinsed thoroughly in clear water.
A quick rinse in a water/vinegar solution followed by another rinse in clear water.
Pat Dry with a lint free cloth and then leave to dry thoroughly for a few hours at least.
Mask with your chosen tape.
On to the painting.  The paint I used was tamiya polycarbonate spray, I test sprayed the inside of the battery cover to see how well it stck and it stck very well.
« Reply #8 on: October 02, 2012, 12:42:02 pm »
Just a quick update.... test sprayed another Futaba TX last night (Son wants his in red) and the polycarbonate paint would not stick.
SO
please check before spraying
« Reply #9 on: October 02, 2012, 11:13:54 pm »
"A quick rinse in a water/vinegar solution" - is that a sort of etch primer?
grasshopper
    • A1 Hobbies Ltd.
« Reply #10 on: October 02, 2012, 11:33:31 pm »
You can get reasonably priced stick radios on 2.4GHz from the likes of Tamco, Code and Etronix.
« Reply #11 on: October 02, 2012, 11:48:30 pm »
... yeah but not in Girlie Pink!  %)
bikerdude999
« Reply #12 on: October 02, 2012, 11:56:57 pm »
Are you planning on painting one to match your err, uhh.... 'colourful' shirts then Martin?
« Reply #13 on: October 03, 2012, 07:58:56 am »
No not really, it just helps to remove any residual soap and oils.... well this is what I was told and it seems to work
Page created in 1.015 seconds with 22 queries.
