Author Topic: please help me to make a 2 way winch from a servo  (Read 2194 times)
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« on: October 03, 2012, 02:17:40 am »
hi guys this has probably been covered before . im trying to make a drum winch for my tug by using a servo to power it . but i want the servo to run both ways . and not just a few turns . i want it running like a real wince .. how can i mod my servo to do it .... the servo is a standard 3003  .. possibly a copy . but surely one of you guys must know an easy way to do it or somewhere i can buy a cheap one already modified !
lets just hope this one floats !!
fire at will ! ... which one is will ?
triumphjon
Re: please help me to make a 2 way winch from a servo
« Reply #1 on: October 03, 2012, 07:52:43 am »
have you looked at the drum winches the model yachts use for pulling our sails in/out ? what is your winch giong to operate ?
Vidion
« Reply #2 on: October 03, 2012, 09:17:32 am »
dont know if it will be suitable for your purpose, but here is a instruction to modify servos
http://www.societyofrobots.com/actuators_modifyservo.shtml
basicly  you glue the pot meter in place and take off the pin wich rotates it , maybe drill out the big wheel so the slot will be round.
important is that you absolutly center the servo before you start.
after the mod servo will run both ways, speed depending how far you push the gimbal ( depending on servo speed also ofcourse )
« Reply #3 on: October 03, 2012, 10:23:39 am »
Heres one I did earlier.  Servo card removed with the position sensing pot and replaced by one of Action's pico ESCs, the end stop lump removed from the output gear tp allow continuous rotation.  Box from Maplin, ali tubing from B&Q.  String is Ryobi Masterline salmon backing.
ian-mccaffrey
« Reply #4 on: October 03, 2012, 02:00:39 pm »
thanx to all the guys who have commented .... ill have a play about tonight . and then let you all know how i got on .... thankyou
Page created in 0.471 seconds with 22 queries.
