Author Topic: One ESC controlling Two motors  (Read 2057 times)
Chaz1940
« on: October 20, 2012, 06:44:05 pm »
Hi everybody
Can you please advise me on how to balance the RPM output of two 545 motors controlled by a single ESC, or would I simply use the rudder trim to offset any tendency to not run straight?
Many thanks %) %)
Re: One ESC controlling Two motors
« Reply #1 on: October 20, 2012, 09:14:08 pm »
You are correct with your assumptions.  You would need to have two balanced motors to run the same speeds to achieve what you want.
It's best to try a run on the water first and assess the boats manoeuvrability.  If there's a problem then perhaps adjusting the prop blades might be the way to go.
« Reply #2 on: October 21, 2012, 07:57:32 pm »
There are two main factors deciding whether the two motors (of the same type) will work together.  There is the loading - meaning the props in the water (matching size, shape, pitch, water flow caused by hull shape for both), friction in the shafts (bearings etc), alignment of couplers and friction in the motor.  Then there is motor efficiency - strength of magnets, rotor to magnet gap, "goodness" of windings and condition of brushes.  If all are exactly equal, no problems.  Provided the conditions are "near enough" equal, then a bit of rudder trim is the answer.
