Author Topic: Plastic glue / weld  (Read 10886 times)
sailorboy61
Plastic glue / weld
« on: November 08, 2012, 02:43:02 pm »
I'm currently using plastic weld, DCM, dichloromethane, Methylene Chloride whatever you want to call it, with which I have been very happy since it discovered it as an alternative to superglue.
I know that others use MEK, Methyl Ethyl Ketone as another weld.
I am about to buy some more, and am considering a bulk purchase which makes it considerably cheaper so I was wondering if anyone had experience of using both and if so whether they had an preference for one or the other?
I suspect like most things, it will fall to personal preference, but I may be wrong, it has been known!
Honestly, I was once.
On an aside, I tried to spell check the first run of this message and it totally disappeared and hence new version. Presuming I did something and it's not a glitch with the new format webpage?
Re: Plastic glue / weld
« Reply #1 on: November 08, 2012, 03:00:51 pm »
This is the one I use.
Liquid solvent cement 500ml
Ref. Code: AM00003
Solvents dissolve a thin film of each surface to be joined forming a welding joint
£10.20 inc. VAT[
Same quantity in Plasweld would be about 25-£30.
http://www.modelshop.co.uk/product/Liquid_solvent_cement_500ml_AM00003
ives,l.html?sortBy=FeaturedDesc
CF-FZG
« Reply #2 on: November 08, 2012, 03:07:57 pm »
For ABS I prefer MEK, for polystyrene and acrylic it'd have to be DiClo.
Mark.
Mark.
Tonka Toys - Big boys toys :)
sailorboy61
« Reply #3 on: November 08, 2012, 03:21:38 pm »
Thanks gents,
looking about £4.7/L DiClo and £9.5/L MEC, certainly pays to buy bulk!
colin
« Reply #4 on: November 08, 2012, 05:14:34 pm »
EMA models also do that one Dicky at £6.50 plus p&p ordered 4 last time as postage was expensive but same cost as one, as it has to be sent by special deliver classed as toxic.
Born free Taxed to death.
Howard
« Reply #5 on: November 08, 2012, 07:55:42 pm »
if any one is near Sheffield I always buy mine from a place called Hindleys 500ml tins and get big sheets of plastic card,660mm, 1330 I think, from 05mm up to 2.75 mm.
                          Regards Howard.
Guy Bagley
« Reply #6 on: November 08, 2012, 08:14:13 pm »
i buy MEK in 25 L drum..... best to buy in bulk
i get it from adhesivebrokers
- they supply all types of adhesives and tapes-
http://www.adhesivebrokers.co.uk/
i have no link to them other than being a satisfied customer
« Reply #7 on: November 08, 2012, 08:17:22 pm »
SSSHHHHHH dont tell everyone but go down to your local B&Q or plummers merchant and buy some PIPE CLEANER dont get the PIPE GLUE much cheaper than the small quantities available to us Modelers,does the same job as everyone has said
Stav
RAAArtyGunner
« Reply #8 on: November 09, 2012, 12:54:41 am »
No you have done nothing wrong, we have all been there, it is the new setup.
It hasn't been explained but the first post you spell check disappears after you active the pop up.
I was always told for security, to never activate pop ups.
However we know Mayhem is reputable so..
RAAArtyGunner
« Reply #9 on: November 09, 2012, 12:58:49 am »
Stav
In Oz the pipe cleaner is for PVC pipes so hopefully we are looking at the same material.
wizard
« Reply #10 on: November 09, 2012, 06:34:09 am »
I had a factory for many years where we sprayed polyurethane foams and hardcoats. MEK was one of the solvents we used and now fortunately, thanks to strict California legislation it has been just about phased out and superceded by safer products.
The reason I mention this is that MEK can be absorbed through the pores of the skin from just the vapour let alone contact. It attacks the central nervous system and is carcinogenic.
Always wear gloves when using it latex ones are no good as it goes almost straight through, neoprene are better.
Pretty much the same applies to acetone. If you buy these solvents you should be issued with a data sheet which tells you the hazards involved in using them.
Wizard
we never really grow up, we only learn how to act in public.
Big Ada
« Reply #11 on: November 09, 2012, 05:34:55 pm »
I am with Stavros on this, as an ex plumber.
Len.
« Reply #12 on: November 09, 2012, 07:40:20 pm »
Yes
slug
« Reply #13 on: November 20, 2012, 05:38:34 am »
stavros hello in b&q they sell small tubes of pipe weld,does this not work on styreen? just wondered as i only need a small amount thank you     slug
Guy Bagley
« Reply #14 on: November 20, 2012, 08:36:30 am »
its likely to be a gel adhesive for pvc pipework, - if it has metyl eythl ketone in its ingredients then yes it will stick styrene
« Reply #15 on: November 20, 2012, 09:34:26 am »
But be careful, too much will distort / melt the plastic
« Reply #16 on: November 20, 2012, 10:56:26 am »
I went to Wicks's store and asked for pipe weld.  I was escorted to the locked cupboard where they had a paste like substance ??
I assumed we are looking for a runny fine liquid. if so, what does it look like and what it's makers name and all that stuff.
« Reply #17 on: November 20, 2012, 11:12:37 am »
Yes it will but if you use to much it will melt styrene.
If you only need a small amount why not buy a small bottle of plasweld.
« Reply #18 on: November 20, 2012, 12:24:22 pm »
  The pipe weld is a gloopy substance. Thinner/Cleaner is the liquid MEK. Might pay to visit a smaller plumbers merchant.
« Reply #19 on: November 20, 2012, 01:09:09 pm »
Ah !!     %)    Thanks for that.
sailorboy61
« Reply #20 on: November 20, 2012, 01:11:33 pm »
Ebay for both MEK and DiChlo, both reasonable in larger quantities, especially if you can share it with someone.
Howard
« Reply #21 on: November 20, 2012, 05:11:57 pm »
If you have a window installer  upvc ask him if you can buy a bottle of upvc solution clean  not the cream stuff about £5 or 6 pound a bottle for 1 lt as good as if not better I was paying £2.99 for a 59ml bottle of plastic weld stuff at my local model shop never again.
                    Regards Howard.
Page created in 0.279 seconds with 22 queries.
