Author Topic: Polyester resin & carbon fibre  (Read 3787 times)
hydrobob
« on: November 13, 2012, 10:13:52 am »
Having used carbon fibre cloth/balsa laminated with epoxy resin in a previous life building conpetition model aeroplanes I want to use the same carbon fibre to strengthen a (very) small hydro hull. For this I intend to use polyester resin for bonding but I have a niggling feeling that I've read somewhere there is a problem with the polyester/cf wetting coverage.
Advice please.
Uneasy Bob
Subculture
    • Dive-in to Model submarines
Re: Polyester resin & carbon fibre
« Reply #1 on: November 13, 2012, 02:28:41 pm »
It's generally recommended to use epoxy resin- you get the best performance from the laminate that way, and epoxy is slightly thinner than polyester usually.
However you can use polyester resin okay, go for it.
hydrobob
« Reply #2 on: November 13, 2012, 04:31:00 pm »
Going to try it this evening. One of the reasons I asked was that I've got loads of polyester and I've run out of epoxy!
Skinflint Bob
tmbc
    • www.tmbc.org.uk
« Reply #3 on: November 28, 2012, 07:29:46 pm »
if you find your resin to think thin it down !
mark
BMPRS  Health and Safety Co-Ordinator
martno1fan
« Reply #4 on: December 09, 2012, 10:34:29 am »
Polyester works fine with carbon fibre its no different than using any other cloth i use it all the time,if your resin is thick put it somewhere warm before you mix it.
Mart
hydrobob
« Reply #5 on: December 09, 2012, 11:46:30 am »
I've done the job now and can confirm that it works ok. Project has now stalled as all funds (ha ha) are being directed to an AA class BMPRS boat. However i will be doing some experiments on various laminate combinations in the near future.
HB
