Author Topic: Twin motors control  (Read 4079 times)
boatman126
Twin motors control
« on: November 22, 2012, 04:52:59 pm »
Is a twin stick RC transmitter (ie Navy F14)the best for a twin motor fast boat?
Re: Twin motors control
« Reply #1 on: November 22, 2012, 05:15:10 pm »
A twin stick controller is a bit overkill for a fast electric,
  .... bit like fitting Satnav to you push bike to go to the local shops ... impressive but nuts!  ok2
If you are think of future, twin motors, multi function boats, etc, it may be worth considering but only if you really need it
Bob K
  • Bob K
« Reply #2 on: November 22, 2012, 05:17:23 pm »
Personally, although the Navy F-14 is a superb piece of kit it may be an overkill for a twin motor surface ship.
Why pay almost 200 Pounds for a 40 Mhz transmitter when a 2.4 Ghz Planet T4 may do the job just as well for almost a quarter of the cost.
If you want differential control of port and starboard props you could use an ACTion P94 controller which has twin ESC’s built in plus a mixer that slows the inboard prop in proportion to rudder movement.  Your boat will turn on a sixpence without having to fiddle with two motor joysticks.
boatman126
« Reply #3 on: November 22, 2012, 05:31:44 pm »
Thank you for your help.
Can I reverse one motor and forward the other at the same time with this system?
ukmike
« Reply #4 on: November 22, 2012, 05:49:54 pm »
Hi.
If you don't have a radio yet then get one that has a couple of mixers.
The current Futaba 6 2.4 is very good.
If you want independent control of the motors then just use two Chan's, one for each motor, after removing the ratchet from the throttle stick.
Re connect the spring and you will have two Fwd / Rev sticks with centre off.
That will give you 1 stick per motor.
If you then mix the two together using Mix1 and designated  ON/OFF mix switch on the Tx. you can couple the two motors onto 1 selected stick.
Easier to do than to read about.
Mike.
« Reply #5 on: November 22, 2012, 06:29:11 pm »
I would go for the ACTion P94 myself.
I have several of these and use them on two channel radios or Planet 2.4 radios.
Excellent piece of kit.
http://www.action-electronics.co.uk/pdfs/P94.pdf
mrlownotes
« Reply #6 on: November 22, 2012, 06:54:12 pm »
Beware :-
The new Futaba 6J and the Action P94 will not work together. I have spoken with Action to confirm this.  The technical explanation is that the mixed channel signals seem to overlap (must be the new technology for speeding up response times).
Skysport 2.4s are the same.
All others should be ok.
There is a warning of this on the Action website on the P94 products page.
Bintur Ellenbach
gerard
« Reply #7 on: November 22, 2012, 07:04:08 pm »
Yes
YOu can reverse one and forward the other with a P94, will turn very fast.
gerard
ukmike
« Reply #8 on: November 22, 2012, 07:05:41 pm »
Provided that the motors are brushed type and you don't want to have the ability to select both motor, (fully proportional), control on one stick.
Mike.
« Reply #9 on: November 22, 2012, 07:43:36 pm »
P94 in a fast electric ??
boatman126
« Reply #10 on: November 23, 2012, 08:49:39 am »
Hi Again
Thank you all for your ideas.
UKMIKE I like the sound of your suggestion.
Will I still have a control for the bow thruster?
Will I still be able to steer the rudders as well as power?
When the alteration to the Tx is made will the sticks spring return to the center?
Is the Mix switch a standard item on this Tx?
Looking forward to your help :-))
ukmike
« Reply #11 on: November 23, 2012, 10:22:46 am »
Hi Boatman.
PM sent.
Mike.
boatman126
« Reply #12 on: November 23, 2012, 10:43:56 am »
Thanks again Mike
Just a couple more questions.
Can both the motors be contolled by one stick with this system?
boatman126
« Reply #13 on: November 23, 2012, 10:44:38 am »
Do you think the control at speed would be difficult?
boatman126
« Reply #14 on: November 23, 2012, 10:47:07 am »
Sorry forgot to ask
Can I use this system with brushless motors?
« Reply #15 on: November 23, 2012, 12:37:57 pm »
Sorry to sound a bit thick, but what model are we talking about?
You said it was a fast model, so why mixers and what use is a bow thruster
on aforesaid 'Fast Boat'
boatman126
« Reply #16 on: November 23, 2012, 02:07:13 pm »
Hi
Yes, the model is to be of a Princess 440 cruiser.
As this is to be a perfect scale replica it has to have a bow thruster as the boat being replicated
Page created in 0.015 seconds with 21 queries.
