December 02, 2025, 11:04:00 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Radio Equipment
jr or futaba
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: jr or futaba (Read 4178 times)
tomaka0
Full Mayhemer
Offline
Model Boat Mayhem Forum is Great!
washington
jr or futaba
on:
November 29, 2012, 07:27:04 pm »
im looking for a min 4 channel tx with the module on back to convert must be cheap
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #1 on:
November 29, 2012, 07:28:04 pm »
sorry 3 channel either jr or futaba
Administrator
Full Mayhemer
Online
Peterborough, UK
Re: jr or futaba
Reply #2 on:
November 29, 2012, 08:48:54 pm »
To convert to what?
Giant Models
triumphjon
Full Mayhemer
Offline
portsmouth , hampshire
Re: jr or futaba
Reply #3 on:
November 29, 2012, 09:24:47 pm »
for the cost of a cheap radio you could invest in one of the planet 2.4ghz sets !
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #4 on:
November 30, 2012, 09:53:16 am »
it needs to be 3 channel with interchangable module futaba jr or hi tec the module i will put in is for a micro plane but i also have a few boats i wih to run with it
Full Mayhemer
Offline
Blackpool, Lancs, UK
Re: jr or futaba
Reply #5 on:
November 30, 2012, 11:15:12 am »
Probably a low cost new 4ch 2.4GHz setup would be cheaper and easier than messing about. Legal for both, as well, and no messing with crystals and wondering if anybody else is on the same channel.
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #6 on:
November 30, 2012, 11:36:09 am »
no the receivers is particular i ll post link
http://www.hobbyking.com/hobbyking/store/__18826__2_4Ghz_SuperMicro_Systems_Receiver_ESC_and_2_x_Linear_Servos_All_in_one_3ch_.html
you will see it has to use 1 of those tx with a micro module
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #7 on:
November 30, 2012, 11:38:40 am »
http://www.hobbyking.com/hobbyking/store/__18820__2_4Ghz_SuperMicro_Systems_HK_MFX600_F_H_Module_Futaba_Hitec_Compatible_.html
.... there is one module there are others but only hi tec, futaba, jr
Full Mayhemer
Offline
Finland, England, Finland!
Re: jr or futaba
Reply #8 on:
November 30, 2012, 11:51:32 am »
You will struggle to find a 3CH tx that will take that kind of module and if you do the price will be quite high
Its also designed for indoor aircraft so the range will not be that good.
Proud member of the OAM (Order of the Armchair Modeller)
Junior member of the OGG (Order of the Grumpy Git)
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #9 on:
November 30, 2012, 12:00:52 pm »
indoor aircraft and pool racer
knoby
Full Mayhemer
Offline
essex
Re: jr or futaba
Reply #10 on:
November 30, 2012, 02:21:09 pm »
several hi tec & futaba module sets on ebay at the moment
The path of excess leads to the tower of knowledge
Full Mayhemer
Offline
Re: jr or futaba
Reply #11 on:
November 30, 2012, 04:21:14 pm »
Scrolling down the page on the link given -
there is a question and answer section, much like this forum. For all I know, the original intended question might have been asked on there, it might even have been answered.
But, from the information as far as I read it - the RX shown will only bind to its associated TX module. That module was only designed for a specific range of modular TXs. If it is required to use it with other TXs, some cutter, plier and soldering iron work is needed, along with some fairly deep electronics knowledge.
tomaka0
Full Mayhemer
Offline
washington
Re: jr or futaba
Reply #12 on:
November 30, 2012, 06:15:46 pm »
you are correct buy modular tx buy corresponding module and rx voila one set for micro plane and swimming pool racer
Print
Pages: [
1
Go Up
« previous
next »
Radio Equipment
jr or futaba
