Author Topic: BLACK ART OF LOFTING A HULL  (Read 2965 times)
stringer
« on: December 27, 2012, 12:47:08 pm »
Hi and a Happy New Year to you all
In 2008 I started a  scratch built  schooner 52" long with a beam of 11" I took my plans from the loftings of the schooner "Bluenose", I finished her in late summer this year, and I would like to start another project, of similar length but wider beam of the volvo 60 racing yacht, here I have photo's and would like to develope my own loftings to produce a similar hull form.
the project would be relitivly easy if I copied the plans of a vo60 yacht, but my intension is to produce my own plans from scratch.
I understand how to produce stations from loftings which creat the form layout throughout the length of the hull having done this to produce my schooner, but coping from an existing lofting is easy, making your own shape hull has me lost
I have produced the full size loft layout of the side view and buttock lines showing the shear and keel profile, also the plan view with the shear line included,next is the body plan view with water line and buttock lines, but no form other than the shear and keel.
So Friends how do I produce the relitive curves that make up my hull without the use of a set of offsets.
Do I make a complete set of curves in the body plan and then take them to the side and plan views to see if they produce a smooth formed hull.
Can someone guide me on how to continue please
regards Stringer
you will never fail as long as you try
Re: BLACK ART OF LOFTING A HULL
« Reply #1 on: December 27, 2012, 03:34:39 pm »
One route would be to use delftship. I think there is a free download that will allow modelling of hulls, and will do 3D.
Just google delftship. There are also tutorials on youtube.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #2 on: December 27, 2012, 11:30:47 pm »
Second on the Delftship, but if you're looking to do it the good old way with pencil and a good eye;
1- You're not lofting, you're designing, so at this stage it doesn't matter (within reason!!!) just how fair the curves are.
2- If you expand the stations onto the centreline in bodyplan view this will give sheer and keel depth at each station. As a designer it is upto you to decide what angle of entry you wish for, where you want the turn of the bilge to be, how much of a tuck you want aft', how much flare to the bows you want and every other detail.
3- I find that if you do the transom, midships station and first bow station aft of the stem they tend to 'fall into place'.
4- Once you have a set of lines that look right to your eye in bodyplan, take the points off your buttock lines and transpose them onto the profile view- creating a grid of waterlines that intersect with the buttocks is the best way to do this. Normally waterlines are tightly spaced on detailed parts- a tight tuck for example- but equal spacing is ok too if your hull form is fairly simple. Draw the waterlines onto profile view and plot the intersections with the buttocks from bodyplan view. The result will be your boats 'lines' a 2D profile of the form of your boat.
5- If you are happy with the profile that's great, but it's rare that a designer is happy first time round, so adjust the lines on the profile view to where you think they should be, once they are somewhere close to looking right, take the plots off the new lines and transpose them onto the waterlines where they intersect with the buttocks on the bodyplan view- you will be amazed how small changes can be on the midship section to make large changes to the lines in profile view.
6- Repeat 4 and 5 until you are happy with the profile and bodyplan views. In true yacht designing the plan view would also be an integral part of the process, but I would suggest you get profile and bodyplan sorted first, then expand the hull into plan view using the grid of buttocks and waterlines from before, but from above. This will show any real problems with the lines under the water, but if you have started with an idea of what shape of boat you want I would have expected you to begin with a basic outline of the hull in plan view in order to give you your plots for the sheerline in bodyplan view.
7- If you are happy with the shape of the boat, photocopy the bodyplan view stations (preferably at an architects or art college where the photocopier has a known accuracy and the ability to scale). Paste the copied stations first onto card, put a small hole through the centreline of each at the waterline- about 1mm dia. Take some none-stretch line (fishing line or similar) and string the stations onto the line. Draw a centreline onto a board, at each end make a braced support (3/4" x 3/4" timber) with a narrow 'V' notch in the centre, narrow enough to trap the line without being able to free itself. On the back side of each support a couple of tacks can be spiked in to make a crude cleat to wrap the line around. THE NOTCHES MUST HAVE THEIR BASES AT AN EQUAL HEIGHT FROM THE BOARD. By pulling the line taught you now have a 3D waterline, and if you have drilled the hole on the centreline of each of the station moulds they will all hang symetrically when viewed from behind or in front.
8- Space the moulds using your drawing. You will now have complete picture of the form of your hull, but in materials that you can modify with a stanley knife and a pot of glue and card.
9- Once you are completely happy with the shape of the boat, and have a set of moulds that you are sure look 100% like you thought they should, put the outlines onto plywood, stick them on your board and pile some planks on top!
NB; the reason that using an accurate photocopier is important is that any error while printing could be hours of head scratching and re-measuring when you bring them home. Another way is to use decent tracing paper.
Greg
« Reply #3 on: December 28, 2012, 01:35:23 am »
Fully agree with the clear series of points offered by gondolier88 as below  :-))  .....they are all important, however I especially like the point ....
"Normally waterlines are tightly spaced on detailed parts- a tight tuck for example- but equal spacing is ok too"
The only additional point that may not be obvious is to only produce 1/2 frame profiles...when complete, transfer these to clear celulose paper & mirror reverse to obtain the PORT & STDB images
Derek.......
stringer
« Reply #4 on: December 28, 2012, 12:03:52 pm »
THANKS FOR REPLYING SHIPMATES
THANKS GREG FOR GIVING ME THE ANSWER I WAS LOOKING FOR, WILL LET YOU ALL KNOW HOW I HAVE GET ON.
REGARDS GEOFF
Page created in 0.115 seconds with 22 queries.
