Pages: 1 [2] 3   Go Down
Author Topic: its my SCHNELLBOOT.. GERMAN F A S C of WW2...  (Read 17266 times)
Krishna
  • aqua plannerrrr....................
Re: its my SCHNELLBOOT.. GERMAN F A S C of WW2...
« Reply #25 on: December 31, 2012, 03:39:18 pm »
have to add three or two washers.. as thrust..
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Krishna
« Reply #26 on: December 31, 2012, 03:41:31 pm »
motor installation.. here i am not incorporating the water cooling system.. because the motor is 10 time powerful than needed here.. the craft is so light.. so, fixing the motor on a simple aluminum heat sink..
Krishna
« Reply #27 on: December 31, 2012, 03:44:02 pm »
motor coupling is again from bicycle spoke, nipple.. and cross drilled for the drive lock.. place..
cross lock is nothing but a simple nail...
Krishna
« Reply #28 on: December 31, 2012, 03:51:24 pm »
insert the nail.. and can lock it by bending it with nose plier..
Krishna
« Reply #29 on: December 31, 2012, 03:53:18 pm »
now drive train is installed on SCHNELLBOOT..time for rudder control..
the rudder panel is from foam board..
Krishna
« Reply #30 on: December 31, 2012, 03:54:36 pm »
as the craft is too light, a 9 gram servo is enough.. simple attatchments..
Krishna
« Reply #31 on: December 31, 2012, 03:56:22 pm »
full drive train is set upped.. now back to detailing and finishing..
adding the grab rails..
Krishna
« Reply #32 on: December 31, 2012, 03:58:21 pm »
more prime coats.. water proofing for high speed operations.. good sealings.. means more thin coats.. adding deck sheet..
Krishna
« Reply #33 on: December 31, 2012, 03:59:59 pm »
the Torpedos...
both spare torpedos are made off some glue caps and appropriate PVC pipe..
Krishna
« Reply #34 on: December 31, 2012, 04:01:19 pm »
glued.. and adding the contra rotating props..
Krishna
« Reply #35 on: December 31, 2012, 04:02:28 pm »
now primed.. and all torpedo racks are paper.. and water proofed..
Krishna
« Reply #36 on: December 31, 2012, 04:03:52 pm »
trial.. and in place..
Krishna
« Reply #37 on: December 31, 2012, 04:05:40 pm »
torpedo racks are completeed.. and waterproofed..
and i do not know what is this device to use.. but still adding.. from plastic tubes..
Krishna
« Reply #38 on: December 31, 2012, 04:06:56 pm »
now finished.. and painted...
Krishna
« Reply #39 on: December 31, 2012, 04:08:28 pm »
depth charges are made of PVC pipes..
and painted..
Krishna
« Reply #40 on: December 31, 2012, 04:10:16 pm »
and the torpedos..
Krishna
« Reply #41 on: December 31, 2012, 04:13:05 pm »
now deck sheet is detailed.. with guns.. and primed..
start to final painting.. this time i dressed her in Dark Ghost grey, is a good tone of camo..stunning all the while..and the bridge is finished in Magnesium Grey..
Krishna
« Reply #42 on: December 31, 2012, 04:15:21 pm »
adding details.. and plexiglass shields.. and a figure.. with range finder..
still i do not know what is the real use of the hook like studs situated in front of the craft painted in orange..
Krishna
« Reply #43 on: December 31, 2012, 04:16:44 pm »
front view and long view..
Krishna
« Reply #44 on: December 31, 2012, 04:20:14 pm »
i couldnt find a black panther on the craft.. so adding a tiger instead.. :-))
 and time of reality..  in mission.. in my first test runs this craft behaved so erratically.. because of the narrow hull, she became too unstable.. and wasnt possible to open throttle a while as tends to roll over.. so back on work table and added passdive and active stabilization systems and measures.. then.. woosh.. now she is a sprinter..
Krishna
« Reply #45 on: December 31, 2012, 04:22:42 pm »
more snaps.. she is a stunning beauty now..
Krishna
« Reply #46 on: December 31, 2012, 04:25:23 pm »
here is the cool action video..
http://www.youtube.com/watch?v=l3--z9hEjJE
vnkiwi
« Reply #47 on: December 31, 2012, 04:27:33 pm »
Once again, your amazing my friend. Well done
vnkiwi
Krishna
« Reply #48 on: December 31, 2012, 04:32:28 pm »
thank you Sir..and wishing you all a Merry Christmas and Happy New Year.. thanks again..
vnkiwi
« Reply #49 on: December 31, 2012, 04:35:19 pm »
And a safe and Happy New Year to yourself and family
Pages: 1 [2] 3   Go Up
