Author Topic: Sheet rubber  (Read 4316 times)
J.beazley
  • The building never ends
Sheet rubber
« on: May 14, 2007, 08:46:34 pm »
Anybody know where i can buy some sheet rubber ???
needs to be about a meter square and 2mm thick or thinner which would be better.
someone come to my aid running out of material options.
Jay
Re: Sheet rubber
« Reply #1 on: May 14, 2007, 08:51:26 pm »
Try these Jay, starts at 3mm off the roll 1.2M wide.
http://www.silex.co.uk/iqs/sid.067279607067909905895/silicone_sheet.html
Richard ;)
omra85
Re: Sheet rubber
« Reply #2 on: May 14, 2007, 08:53:19 pm »
It's no good, I can't resist it.....
There's a little shop in Amsterdam which does all sorts of latex and rubber..... or
How about mugging a local surfer ;D
Seriously, wetsuit material is about that thick, but where you would find a worn out wetsuit, I don't know ???
Danny
Re: Sheet rubber
« Reply #3 on: May 14, 2007, 08:58:02 pm »
This one is probably better.
http://www.yellowcatshop.co.uk/shop/default.asp?clientid=14&gid=4dmod&viewstate=32769&tabcatid=3500106&subcatid=3500115
Ignore Danny , he's obviously escaped again.
Get back to " Wheres this then " Danny.
Richard ;)
grasshopper
    • A1 Hobbies Ltd.
Re: Sheet rubber
« Reply #4 on: May 14, 2007, 09:07:46 pm »
Cheaper option, but questionable size - inner tubes from old truck tyres - go see your local tyre fitter.
Wet suits are usually neoprene - check out your nearest scuba dive centre... or look at the local swimming pool, they usually practice or advertise there
J.beazley
Re: Sheet rubber
« Reply #5 on: May 14, 2007, 09:21:12 pm »
the use of the rubber is for one of my hovercrafts skirt, the usual material for this is rip-stop nylon but i want to make one out of thin rubber.
Jay
BobF
Re: Sheet rubber
« Reply #6 on: May 14, 2007, 09:27:54 pm »
What about Neoprene pond liner. I think that is about the thickness you are after.
chingdevil
Re: Sheet rubber
« Reply #7 on: May 15, 2007, 11:50:01 am »
Hi Jay
I have some 1.5mm white silicone rubber, anygood?
The other Brian
J.beazley
Re: Sheet rubber
« Reply #8 on: May 15, 2007, 01:19:20 pm »
cheers for the offer Brian, just ordered myself some 0.5mm thick sheet rubber from the link above.
Jay
Ian Robins
Re: Sheet rubber
« Reply #9 on: May 21, 2007, 08:55:24 pm »
hi jay,
pm your phone number as I have 0.5mm rubber sheet,
need to get it to you from Northampton unless anyone can collect from mayhem weekend for you
ro88o
taxi
Re: Sheet rubber
« Reply #10 on: May 21, 2007, 09:06:18 pm »
Try scrounging some from a BT cable jointer.   About 3 ft wide and on a roll, adhesive one side, sticks very well to it's self and is used as a temporary cable joint closure.   Good for sound deadening panels on car.   BT vans are also a good source of lead, copper wire, tape, crimps, tools, shrink down closures of various sized, blue towel, etc. etc.
alan colson
  • I Just Dabble In Model Boats
Re: Sheet rubber
« Reply #11 on: May 23, 2007, 04:15:04 pm »
Try a litho print company, they throw away their damaged printing blankets.
swordfish fairey
Re: Sheet rubber
« Reply #12 on: May 31, 2007, 10:33:18 pm »
Hiya Jay, did you get any sheet rubber??, if not I may have some that will be of use to you.........Tony
Re: Sheet rubber
« Reply #13 on: May 31, 2007, 10:40:44 pm »
Yes, he picked it up today.
I got it at mayhem sunday.
Thanks ro88o
Page created in 0.03 seconds with 22 queries.
