Pages: 1 [2] 3   Go Down
Author Topic: Is this a crazy idea?  (Read 12061 times)
Lash151
Re: Is this a crazy idea?
« Reply #25 on: February 13, 2013, 10:51:35 pm »
Its OK, I'm not any more confused than normal  :-))
I posted a new topic in the Submarine section... I think I shall scratch build a submarine out of styrene... I just need to find some suitable plans.... either an Akula or a British WW2 sub... not sure yet!
Lee
Howard
« Reply #26 on: February 13, 2013, 11:37:05 pm »
Emm, after reading my last post (see above) I think I should stop drinkng Stella as even am finding it hard to read that and I wrote it. %%
             regards Howard.
G2012
« Reply #27 on: February 14, 2013, 12:02:58 am »
This is a very interesting thread.  I am about to start building a tid tug hull from styrene sheet.  The hull will be about 600mm so not a large hull.  I plan on using 2mm thick sheets for the frames and 0.75mm sheets for the outer skin of the hull.
Lash151
« Reply #28 on: February 14, 2013, 12:21:48 am »
What made you choose this method, had you seen it before?
G2012
« Reply #29 on: February 14, 2013, 01:48:50 am »
Primarly because working with styrene doesnt make as much mess as wood.  I will be doing the build in my 1 bed flat and have no workshop so keeping the mess to a minimum is a good thing.  I also quite enjoy working with styrene and always promised myself I would give building an entire hull from the material a go some time.
NickelBelter
« Reply #30 on: February 14, 2013, 07:14:03 am »
To clean up the edges of scored and snapped styrene sheet, a small block plane does a lovely job.  You can even buy a miniature edge plane from Veritas that will keep your edges square.
Lash151
« Reply #31 on: February 14, 2013, 09:43:19 am »
Thanks... I will check that out. I use a small plane with a razor blade in it at the moment... that works well.
Lee
Lash151
« Reply #32 on: February 14, 2013, 09:46:11 am »
Do you find it difficult to snap 2mm styrene along a score?  I am just thinking about scoring and breaking 2mm along curved edges... I haven't used 2mm stuff before.... I will have to get some and experiment.
Lee
« Reply #33 on: February 14, 2013, 11:24:30 am »
Topic cleaned up and Gaou's random post moved.   :-))
http://www.modelboatmayhem.co.uk/forum/index.php?topic=41084.0
Lash151
« Reply #34 on: February 14, 2013, 12:43:50 pm »
Thanks Martin...
I think Gazou's photograph of himself did work surprisingly well under the heading 'Is this a crazy idea?'  :}
Lee
« Reply #35 on: February 14, 2013, 12:58:26 pm »
G2012
« Reply #36 on: February 14, 2013, 01:58:27 pm »
Lee
It has been a few years since last time I worked with styrene but from what I remember it wasn't too bad.  I was. Hoping to have started by now but struggle to find the spare time these days!
« Reply #37 on: February 14, 2013, 03:42:05 pm »
How about a build thread :}
Lash151
« Reply #38 on: February 14, 2013, 03:54:29 pm »
Yes, I would be very interested in seeing a build log of your TID
Lee
Arrow5
« Reply #39 on: February 14, 2013, 04:06:56 pm »
Lash, I dont think that is Gazou`s photo. I`ve bought a few postcards of this image in the past, it is the French version of a Scotsman in a "see you Jimmy" hat! %)     If is him then he is doing OK on royalties ! {-) {-) {-)     Merd,  juis oui gone off topic again :((
..well can you land on this?
« Reply #40 on: February 14, 2013, 04:15:41 pm »
Oui, garder au point s'il vous plaît ; vilain garçon
 ;D
Lash151
« Reply #41 on: February 14, 2013, 05:08:02 pm »
 ;D
singe effronté
RAAArtyGunner
« Reply #42 on: February 14, 2013, 07:45:27 pm »
Me no speeka dat lingo >>:-( >>:-( >>:-(
Arrow5
« Reply #43 on: February 14, 2013, 07:58:18 pm »
Strewth Bruce...we dont understand Strine neither. Now your gonna get carded, plastique of course. <*< <*< <*< <*< {-) {-) {-)
G2012
« Reply #44 on: February 14, 2013, 08:07:55 pm »
I will start a build thread as soon as I start the build!  I am hoping to get the prop shaft ordered tomorrow as well as handing in a university assignment.  Hopefully I will be able to get started soon after that is done.
Lash151
« Reply #45 on: February 14, 2013, 08:09:55 pm »
Great, I look forward to watching the build....
Lee
RAAArtyGunner
« Reply #46 on: February 14, 2013, 08:10:18 pm »
Vot coontree yoo all cum a da vrom, hoo no cun speeka da ingliz  <*< <*< <*<
Vos did rine, me speeka da goot ingliz, >>:-( >>:-( bin stralia long long time,  O0 O0 me play da cards good, pocker goot huh O0 O0 O0
G2012
« Reply #47 on: February 14, 2013, 08:22:40 pm »
Lee
I am looking forward to getting started! :}   It has been 4 years since last I did any model boat building.
I asked a similar question a while back and was advised to have a look at some of Krishna's builds but I believe he used foamex boards.
Lash151
« Reply #48 on: February 14, 2013, 08:25:55 pm »
Krishna's building techniques are unique... he builds whole boats in a day!!
G2012
« Reply #49 on: February 14, 2013, 08:27:40 pm »
Yes, I noticed that.  It will probably take me a day to get all the frames for the hull cut out!
Pages: 1 [2] 3   Go Up
Page created in 0.039 seconds with 17 queries.
