Author Topic: Props/Multiple motor single shaft drive  (Read 7479 times)
Re: Props/Multiple motor single shaft drive
« Reply #25 on: February 17, 2013, 04:50:32 pm »
If you go for a brass prop its more than the tug is worth.
sean Half-pint works
  • Because I can!
« Reply #26 on: February 17, 2013, 04:57:07 pm »
Fair point indeed Ned... hmmm a cununderum now... I think the thing to do now is get her battery and see how she goes... I do admit I have fallen in love with my little tug...
Semper fidelis
BarryM
« Reply #27 on: February 17, 2013, 05:02:27 pm »
Sean,
Ned may well be right. It depends on how much you want to develop your model.  Try your new battery first and then work from there.
In respect of prop/nozzle clearance, full-size practice relies on a gap of a few millimetres. Model practice should give a running clearance and no more if you want the best Kort effect.
Barry M
  • Because I can!
« Reply #28 on: February 17, 2013, 05:07:27 pm »
Thanks Barry and Ned, I will let you know how things get along...  O0
As always thanks for the advice lads, and sorry if I seem a little dim.. Im still finding my sea legs...  ;D
Semper fidelis
« Reply #29 on: February 17, 2013, 05:29:34 pm »
Sean,
Why I asked is if you search the other conversions most keep the motor and prop as this gives more than adequate performance.
If you start putting larger props on a 540 motor you will certainly improve the performance to that of a speedboat and increase the current draw from the motor.
To check the battery put a voltmeter across the battery when running in the bath.
  • Because I can!
« Reply #30 on: February 17, 2013, 10:47:52 pm »
Hi Bob,
I just popped the hull and contents in the bath and the battery voltage is way down on its stated 6.5 volt... I charged it till the charger light turned green, left it ti stabilize for a little while (about an hour or so) popped it into its connector any my voltmeter was ticking (i call it ticking) at 4 volts... then mum shouted at me for my tug being in her newly cleaned bath...  {-) {-) :police: >>:-(
sean...
Semper fidelis
  • Because I can!
« Reply #31 on: February 17, 2013, 10:49:58 pm »
Tug racing anyone??? (jokes) thanks for the heads up though!
Semper fidelis
old shrimper
« Reply #32 on: February 17, 2013, 11:40:04 pm »
if you increase the blade surface or size  and put a bigger redaction on the current motor it will improve the towing ability , but not effect the free running speed a lot
 IN THE REAL WORLD hull design only lets the boat go so fast then it starts to push water and bury its self , like most tugs  witch are over powered  for there  water line length
BUT hook them up to a dead pull and they will move the earth ( love um )
and it should reduce the batterie drain  (less load on the motor ) you can always free run at half throttle if you have to much POWER  {-)  like i will have to do 60mm 4blade brass prop on 6 .1 red with mfa 540 on 12 v if you hold yer hand  at the bow and not let it go forward at full noise it will bury the stern
50 YEARS OF TOWING NETS
  • Because I can!
« Reply #33 on: February 18, 2013, 12:01:12 am »
I like that statement, although she lacks the manuverablitiy for true tug towing events, but still I can have fun with her!
I believe this is why tugs have the high bow, almost like the atlantic bows on some naval vesels?
Thats the best bit! Nowt wrong with pulling 4 barges at a time!
Is there such a thing as too much power on a Tug? from what I have seen the Dickie is fairly robust, and a couple of well handled examples should easilly cope with even 1:76 scale warships of the biggest proportions... Do you have any photos of the reduction set up please? Eventually I want to build a warship of some kind (probably a battle cruiser type) when I have gained alot more experiance in things model boat... I don't think I will try and bury the stern...
however I still think tug racing could be amusing!  {-) O0
Finally, Shiny parts  ;D
Sean
Semper fidelis
old shrimper
« Reply #34 on: February 18, 2013, 12:46:14 am »
HERE IS A PDF of all the motors they make
http://www.mfacomodrills.com/pdfs/gearbox_colour_brochure.pdf
and a pic of mine is on page 9
sorrey about the size of the page (dont know how to enlarge it) theres more spec lower down on the page to
old shrimper
« Reply #35 on: February 18, 2013, 01:18:39 am »
« Reply #36 on: February 18, 2013, 05:03:25 am »
Guys....this one had me scratching for the grey cells  :(( until I saw that the FWD motors were actually for the reversable pitch propellers
This electrics/motors are a real credit to the builder  :-)) ...... http://www.youtube.com/watch?v=JXMtpmDD06I
Here is another link to the bow thruster setup....http://www.youtube.com/watch?v=xjCFhQzdWhI. ........Derek
old shrimper
« Reply #37 on: February 18, 2013, 06:15:25 am »
WOW it amassing what is out there
great stuff
old shrimper
« Reply #38 on: February 18, 2013, 06:57:03 am »
here is a bit of info i found about sizing motors /props etc
 http://www.building-model-boats.com/model-boat-motor.html
  • Because I can!
« Reply #39 on: February 18, 2013, 07:23:29 pm »
Thanks all of you for the bits and bobs of advice, guidence and putting up with me and my curiosity!
All the best
Sean
Semper fidelis
Page created in 0.212 seconds with 22 queries.
