Author Topic: 1/6 scale seats  (Read 4385 times)
surfs up
1/6 scale seats
« on: February 22, 2013, 11:42:42 am »
Anybody at there know of any suppliers of 1/6 scale boat seats?
Wanted for airboat.
Surf
Re: 1/6 scale seats
« Reply #1 on: February 22, 2013, 11:57:57 am »
Your down to the Toy shop selection here. If you knew the height of the chairs then this might be the answer.
Re: 1/6 scale seats
« Reply #2 on: February 22, 2013, 12:47:27 pm »
Wow! That's BIG.
Action Man size.You may need to fabricate your own, which should not be too hard at that scale.
Maybe look at some of the RC model car seats.
Hasbro also do 1/6 scale military vehicles with bench seats.
ardarossan
Re: 1/6 scale seats
« Reply #3 on: February 22, 2013, 01:18:50 pm »
Wanted for airboat.
Surf
What kind of design are you ideally after?
How much wood would a Woodchuck chuck, if a Woodchuck would chuck wood?
Re: 1/6 scale seats
« Reply #4 on: February 22, 2013, 01:29:16 pm »
An Airboat type design
  Regards Ian
ardarossan
Re: 1/6 scale seats
« Reply #5 on: February 22, 2013, 01:42:47 pm »
  Regards Ian
Have you seen the variations in Airboats seat designs?, then there's single seats, double seats, triple seats?, what material is it supposed to represent? wood slats?, steel tubing?, aluminium bucket? canvas or vinyl?, what period airboat model is it? and maybe the quantity required would be useful too...
Perhaps the originating poster might be better off responding.
Andy
Re: 1/6 scale seats
« Reply #6 on: February 22, 2013, 01:56:39 pm »
And perhaps Kenny and Tiger have already given a clue to where the O/P may start to search? :-))
  Regards  Ian
Re: 1/6 scale seats
« Reply #7 on: February 22, 2013, 02:04:50 pm »
I was thinking of a kitchen chair with wood slats.     %)
Ken
Re: 1/6 scale seats
« Reply #8 on: February 22, 2013, 02:08:27 pm »
Might need ejector seats if it's Gas turbine powered? %%
  Regards  Ian
Re: 1/6 scale seats
« Reply #9 on: February 22, 2013, 02:27:09 pm »
Use alligator clips to hold it in place  O0 O0 O0
ardarossan
Re: 1/6 scale seats
« Reply #10 on: February 22, 2013, 02:31:14 pm »
  Regards  Ian
And perhaps there are other alternatives which may be as good, if not better, than the two non-specific suggestions provided, and if the O/P gets a chance to reply and expand on what they are ideally looking for.
Andy
surfs up
Re: 1/6 scale seats
« Reply #11 on: February 22, 2013, 04:42:53 pm »
Thanks for the replys guys. I was just trawering to see if anyone new of any off the self seats, I was leaving the final seat arrangement till I could find some seats.
The boat its self is a bit on the big side around 2 1/2 foot by 1 foot powered by a 7 inch prop on a brushless motor
I have a set of drawing for millennium falcon seat that may see if I can get 3D printed put I think they maybe to large to print
surf
ardarossan
Re: 1/6 scale seats
« Reply #12 on: February 22, 2013, 06:21:57 pm »
I've got a couple of diffrent model-Aero seats that are basically moulded shells with padding on them, and I also have a R/C buggy with a similar scale seat fitted. If you knew what you wanted, might be ble to fix you up, or take measurements for you to make your own.
There are also some cockpit kits available, and a range of seat-belts, harnesses, joysticks, instruments, etc, but they might not be substantial enogh for your purpose, and they can also be a bit pricey, but it's another avenue of investigation.
With reference to (model) aircraft seats, especially those fitted to 'between the wars types', the seats aren't much more than a basic shell or bucket and similar to some of the Airboat seats, and are also relatively easy to replicate using the appropriate section of a suitably-sized/shaped plastic bottle or container, then just add the necessary framework to suit your model.
How to cut a square bottle, and/or £20 for a 'scale' Focke-Wulf FW.190 Seat?
Page created in 0.062 seconds with 22 queries.
