Author Topic: Solent class lifeboat  (Read 4249 times)
Neilfalcus
« on: March 04, 2013, 09:50:55 pm »
First attempt at this!  I'm making a solent class lifeboat and would like pictures of same. The moulding I have differs from the drawing provided. I have got plans from rnli but there is no detail of masts radar etc rather in the dark at the moment. Help apprecitated Neil
gribeauval
Re: Solent class lifeboat
« Reply #1 on: March 04, 2013, 11:18:42 pm »
First thing is to decide which boat you want to build as they all differ slightly!
Check out this link for pictures:
http://www.google.co.uk/search?q=solent+class+lifeboat&hl=en&client=opera&hs=af0&channel=suggest&tbm=isch&tbo=u&source=univ&sa=X&ei=KSs1UYS-FMnRtQbtk4HQDA&ved=0CDAQsAQ
True Lifeboat Nutter!!
Neilfalcus
« Reply #2 on: March 05, 2013, 07:16:12 pm »
Thanks for your reply mike. My model has sliding doors pMoulded on cab and what look like a dozen roof lights on cabin
heritorasphodel
  • Inactive
« Reply #3 on: March 05, 2013, 09:00:45 pm »
Does it have three roughly equal size squarish windows in the front of the wheelhouse, or does it have a larger centre piece?
Andrew
Neilfalcus
« Reply #4 on: March 06, 2013, 12:36:58 pm »
The boat has roughly equal windows at 50,60 and50mmacross. Does this help thanks andy
heritorasphodel
  • Inactive
« Reply #5 on: March 06, 2013, 02:32:48 pm »
That does help, narrowing it down to three boats, 48-014, 48-015 and 48-016, the Mk2 Solent. Both 014 and 016 have solid watertight doors either side of the wheelhouse, while 015 had clear sliding doors fitted over the holes left by the watertight doors being left off. Seeing as your model has sliding doors, it is most likely 48-015.
ON 1019, 48-014, Lady MacRobert, Montrose and Relief
ON 1021, 48-016, Douglas Currie, Served in lots of places.
Unfortunately I don't have any photographs of ON 1020, 48-015 Hugh William, Viscount Gough. Aside from the doors, number and name she would have been fairly identical to these two. As far as I know, the Douglas Currie is the only one of the three still in full lifeboat livery and almost entirely original (aside from the number being removed). She attends lifeboat rallies quite often.
Do you have any photographs of your model? The reason your drawings differ from the mouldings is the drawings are probably a Mk 1 Solent, with a different superstructure.
Andrew
Neilfalcus
« Reply #6 on: March 08, 2013, 09:54:42 am »
Andrew thank you for your detailed reply and photos which are really useful as I have no photos of the masts etc. knowing the boat number and name should prove useful. I do not have any photos as I have just started on the model this is not my first attempt to thank you but other attempts seem to disappear -hopefully this will reach you cheers Neil
heritorasphodel
  • Inactive
« Reply #7 on: March 08, 2013, 10:18:02 am »
No problem Neil, that's what we're here for  :-))
Andrew
Page created in 0.017 seconds with 22 queries.
