Author Topic: Keil Kraft Eezebilt RAF Crash Tender  (Read 9418 times)
VC
« on: March 09, 2013, 06:50:19 pm »
Scaled the plans to 130% to arrive at a bigger boat ( 26"). Build started on 24th Feb. I'm using 3mm ply and Foam Board in various thickness (2mm - 5mm) for this build. I've also managed to procure some drive sets with universal joints - this is a rarity in India.
This is where the build stands today. Yet to decide whether to do a brushed or brushless set up.
p.s. In the 7th. Picture, you can see the Mermaid alongside this model.
Growing old is mandatory, growing up is optional.
montessa315
  • I should do it which way?
Re: Keil Kraft Eezebilt RAF Crash Tender
« Reply #1 on: March 09, 2013, 07:18:44 pm »
Coming together well.
What are you using to glue the foam board?
Alan..............
If you always do what you've always done, you'll always get what you've always got.
eddiesolo
« Reply #2 on: March 09, 2013, 08:27:25 pm »
Looking good there.  :-))
Si:)
VC
« Reply #3 on: March 10, 2013, 04:27:02 am »
Thank you!
I'm using a CA that is specially formulated for Foam Board and Acrylate. Will strengthen all joints with epoxy before I apply the skins.
VC
« Reply #4 on: March 12, 2013, 07:06:11 pm »
I've started work on the superstructure today. A lot needs to be done to modify/rectify the plans. The notches denoted on the plan aren't deep enough and will result in an incorrect profile. BEWARE!!!
Mad_Mike
  • Lincolnshire
« Reply #5 on: March 12, 2013, 08:13:01 pm »
another guy building boats using foam board i cannot find this stuff anywhere {:-{
You got your hands full with all these boat projects going, they are all coming on well too.  :-))
VC
barriew
« Reply #7 on: March 13, 2013, 07:38:37 am »
Have you tried arts and crafts stores - Hobbycraft sell it if you have one near you.
Barrie
Mad_Mike
  • Lincolnshire
« Reply #8 on: March 13, 2013, 03:53:14 pm »
i dont reckon ive ever seen any. whats it like? Is like that stuff they use for packing that when you break it leaves little polystyrene balls everywhere or is like the trays you get from the chippy?
VC
« Reply #9 on: March 13, 2013, 04:47:07 pm »
Neither. You are talking about Thermocole. Depron is somewhat similar to Thermocole. This foam board is denser and heavier which makes it practically useless for aero modelling. PM me your address and I'll send you some samples of this stuff.
Cheers!
VC
« Reply #11 on: March 13, 2013, 05:39:26 pm »
Oh no! This isn't getting anywhere. Circlip, that isn't what I am using. The link points to a lovely material (Foam Core Board) prized by aeromodellers. It is a sheet of depron (?) sandwiched between two laminates. The foam that I am using is very dense and, anything above 3mm, requires a bit of effort to cut with a modelling knife. It is Rigid PVC Foam Board. Ideal as a Balsa replacement for bulkheads, Superstructures and perhaps, Skinning (Must try that someday).
I am travelling outstation tomorrow and will be able to log in again only on Monday. Then I shall attempt to post close up / cross section photographs of Depron / The foam that I am using/ The foam pointed out by Circlip.
Cheers!
Edit: Thought I would do it right away. :-))
Pic 1. Depron
Pic 2. Foam Core Board
Pic 3. Rigid PVC Foam Board - The one that I am using.
VC
« Reply #12 on: March 13, 2013, 06:02:15 pm »
Rigid PVC Foam Board is available here in the UK and Ireland:
http://www.antalis.co.uk/content/Foam_Rigid_PVC_Board.aspx#
Hope that helps.
Good night from India. :-))
« Reply #13 on: March 13, 2013, 06:15:39 pm »
Just think what problems we had when there was only soft/medium/hard Balsa  {-)
  Have seen the foamed PVC you're using VC, is there a manufacturers or product name on it?
   Sorry, just seen your last link.
VC
« Reply #14 on: March 13, 2013, 06:24:42 pm »
Yes and the smell of Balsa and Adhesive was maddening. %% We didn't have cellphones or the net either. Life was easier, but then again, could we be in touch this way - half way across the world?  ok2
C'est la vie Mon Ami!
Completely forgo to post the progress photos for today.
Side decking added. Either I went wrong on the cut or the plan needs SERIOUS amendment. I will blame the former.
Visited the neighbourhood Car License Plate printer and got a template created for the FIRE lettering. Paste/ Spray/Wait/ Peel away - should be a cinch. Only time will tell.
Rudder made out of 6mm ply.
Work will resume on Monday again.
tt1
« Reply #15 on: March 13, 2013, 06:30:18 pm »
Have used foam board for all sorts during modelling, strong, very light - much lighter in weight and more rigid than styrene of equal thickness and once glued with cyano (even on edge) it ain't gonna come apart.  Have made boat stands, battery trays, servo boxes etc etc and of course it's waterproof.
          Happy to make the same offer as VC Ian if you wish to pm me your address.
                                                 Regards, Tony.
VC
« Reply #16 on: March 13, 2013, 06:41:44 pm »
There you go Chaps! Lester is closer home than Guwahati! {-)
Thanks Tony! O0
Mad_Mike
  • Lincolnshire
« Reply #17 on: March 13, 2013, 07:35:09 pm »
thanks for clearing that up. Ill buy some and see what i can do with it.  :-))
« Reply #18 on: March 13, 2013, 07:56:10 pm »
Got some thanks Tony but mines in the form of a piece of extrusion used in the plastic window/door trade as a trim strip. Although one supplier sells both types, he refers to Foam PVC and paper/exp poly/paper both as foam board. If you regard the Paper/exp poly/paper, there is both expanded polystyrene  and polyurethane variants. The "original" (?) paper/styrene/paper was projected for use in toy aircraft years ago when there was a colossal increase in the price of Balsa by cutting shaped panels from it and glueing balsa strip to the "Open" edge. Then there's Depron  %)
  Don't matter too much on a boat but weight might be a problem. Definitely will if used on topsides.
« Reply #19 on: March 15, 2013, 01:23:43 pm »
And there's more :- http://www.tri-dee.com/Sintra%20sheets%20information.htm same song, different singer. Bit of information on usage and other types of material.
  Regards  Ian
VC
« Reply #20 on: October 20, 2013, 06:33:08 am »
How does one get hold of this magnificent set of detailing kit without paying for it? <:(
VC
« Reply #21 on: October 20, 2013, 06:34:34 am »
Indulge in a bit of masochism and build the entire lot (and more) from scratch........ O0
TheLongBuild
  • Build em, and play hard..
« Reply #22 on: October 20, 2013, 10:23:48 am »
Any updated pictures of the boat ?.
VC
« Reply #23 on: October 20, 2013, 11:11:29 am »
I just can't seem to be able to post any pictures here.
The boat is almost ready, you can see the build here:
http://www.rcindia.org/boats/scratch-from-plan-built-raf-crash-tender/
Regards.
« Reply #24 on: October 20, 2013, 11:34:05 am »
Visitors are only allowed to view one picture per posting on your site.
Regarding posting on here, it's simple enough.
1.  Click on attachments and other options
2.  Click on browse
3   Click the picture from your computer which is under 150K
4.  Click  Open
5.  Repeat procedure if you have another picture
6.  Click  Preview
7.  Smile and click  Post
Hope this helps,
Ken
Page created in 0.188 seconds with 21 queries.
