Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: Building the FV Cornelia Marie  (Read 179635 times)
missyd
Re: Building the FV Cornelia Marie
« Reply #50 on: August 26, 2013, 08:53:21 am »
Thank you  very much for info abour the bow! I was thinking of changing the shape to a more pointed version ... but I wasn't 100% if it would come out OK. Now I will leave it as it is!
Danielle
Tugboat Andy
« Reply #51 on: August 27, 2013, 02:29:34 am »
Designers all have their own ideas about how a boat will move through the water. A sharp entry might blow through a wave rather than lift with the wave. A blunt bow may slam and pound.
Here's a couple teaser pictures of the bow of the Time Bandit for comparison.
« Reply #52 on: August 27, 2013, 03:10:34 am »
Just a question Andy........the location looks like a disused stone quarry  %) ....how do the intend to re-float the vessel?....40 days & 40 nights of rain?....... {-) ....Derek
missyd
« Reply #53 on: August 27, 2013, 06:38:16 am »
I think this bow on the time bandit is ugly ... maybe it saves some fuel?  %)
The crabbers need to be very stable in very bad weather. No need to go fast or powerful for big trawling nets.
Danielle
missyd
« Reply #54 on: August 27, 2013, 06:45:52 am »
Added another 9mm to the top of the bow. Had to do this because the bow was too low (or the crab pots a little too big). They have to fit under the shelterdeck.
Then I made corrections to the cardboard mockup. A little bit more sloping to the back and rear sides. Couldn't resist to put all crab pots on deck to see if it looks ok!!! Looks just fantastic!!!!
Danielle
deadwood
« Reply #55 on: August 27, 2013, 11:29:33 am »
Maybe they are going to swamp the quarry with shale oil?
deadwood
« Reply #56 on: August 27, 2013, 11:46:49 am »
Never having watched the Deadliest Catch (lack a satellite dish to receive those Reality TV committed channels) I cannot say what the hull of the TIME BANDIT used to look like.
But this protruding cylindrical bulb to me looks like having been retrofitted later, post-delivery so to speak.
As the diameter of its cylinder doesn't look too wide and the structure of cylinder and semi-sphere quite sturdy, I think the perils of slamming aren't excessive, despite the Alaskan notoriously heavy sea.
If it helps cutting fuel costs in moderate sea states.
missyd
« Reply #57 on: August 27, 2013, 01:27:54 pm »
The bulb was retrofitted 2 years ago ... maybe we should open another topic about king crabbers?  ;)
Danielle
missyd
« Reply #58 on: September 17, 2013, 09:27:58 am »
Just to pics ... after my summer holidays I started to build some more stuff in cardboard to check if everything fits together.
Danielle
GAZOU
« Reply #59 on: September 17, 2013, 09:35:37 am »
it is to sleep the last baby of the family  {-) {-) {-)
« Reply #60 on: September 17, 2013, 12:00:35 pm »
You speak in riddles Gazou............ do you have a famous footballer as a son.........Eric Cantona..
he spoke similarly, of strange thoughts, and I never had a clue what he was talking about either? %% %% %% %% %% %% %%
GAZOU
« Reply #61 on: September 17, 2013, 01:10:05 pm »
it is the cradle of the latest    ?
Eric CANTONNA  is a great player and now a good actor    O0 :-))
And a great humanist O0
missyd
« Reply #62 on: September 18, 2013, 07:41:35 am »
Some more pics of my cardboardworks!!! Everything looks alright and I can build the rest of the CM!!! It looks very impressive in real size! The hull shape is different than all model ships you see normally.  ;)
Danielle
missyd
« Reply #63 on: September 24, 2013, 11:09:17 am »
Built the support for the e-motors and they fit nicely in the hull ...
Danielle
Tugboat Andy
« Reply #64 on: September 30, 2013, 02:01:51 am »
Looks good! I like you motor mount.
missyd
« Reply #65 on: October 09, 2013, 08:54:53 am »
I started to add the 2nd. layer of planking to the hull. Very nice this 1.2mm plywood.
Danielle
missyd
« Reply #66 on: October 17, 2013, 08:46:13 am »
Still working on the planking ....
The bigger brass tubes will go over the existing ones an on it I will solder the reinforcement profiles and rudder attachments ...
The planking on the bow was glued and nailed on place ... nailheads will be sanded and invisible afterwards ...
Danielle
missyd
« Reply #67 on: October 18, 2013, 06:58:49 am »
Finished the lower bow section ... still needs some sanding and filler ....
Danielle
missyd
« Reply #68 on: November 05, 2013, 12:46:44 pm »
I've done most of the lower planking during the last weeks. Now I have to fill-up all the imperfections with putty.
The nailheads will be sanded away with the putty ...
I do not intend to make a very smooth hull as the original looks very beaten up!!!
I went to the modelfair at Friedrichshafen in southern germany last weekend. I found some really small 1:700 geared 3V motors for the radars. They are used in the 1/87 RC-Cars ....  :-)
Very expensive at 24.50 Euro but I think smaller motors do not exist ...
http://www.mikromodellbau.de/Shop/artikeldetails.php?aid=973
Danielle
missyd
« Reply #69 on: November 06, 2013, 02:57:10 pm »
With my oscillating sander I sanded all the putty to a smooth surface. Just a matter of a few minutes!! Nailheads are flat with the 1.2mm plywood.
Next step is to install the rudders and reinforcement bars for the rudders. Everything will be made out of brass profiles.
Danielle
« Reply #70 on: November 06, 2013, 04:36:44 pm »
Have you got a picture of your oscillating sander please.  It sounds just the job.
Ken
« Reply #71 on: November 06, 2013, 08:16:43 pm »
Ken ,sander is in the pics it looks like a Black and decker/bosh type
« Reply #72 on: November 06, 2013, 08:40:57 pm »
Yes Stavros.......definitely appears to be the Bosch........Derek
missyd
« Reply #73 on: November 07, 2013, 06:39:01 am »
Yes its exactly this Bosch model! I like it a lot. It sand to a very smooth surface even with 80grade sandpaper and quick!!!!!
Danielle
« Reply #74 on: November 07, 2013, 07:10:11 am »
missyd ........
1. you are now embarking on the path of painting...........could I suggest that you re-read the full detail by Stavros [Dave] in the Painting thread here on MBM ....where Dave nominates W&D paper down to 1200 from memory........
2. are those pin nails brass or iron?.........
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16   Go Up
Page created in 0.538 seconds with 22 queries.
