Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: Building the FV Cornelia Marie  (Read 184320 times)
Grace2
Re: Building the FV Cornelia Marie
« Reply #150 on: April 08, 2014, 12:51:32 pm »
lovely work.....boat looks amazing  O0
missyd
« Reply #151 on: April 08, 2014, 06:07:59 pm »
Thanks a lot Grace.
Started with the planks on the deck today ....
Danielle
bassplayer1
« Reply #152 on: April 09, 2014, 01:07:58 am »
Your work is amazing!!!! Absolutely fantastic! :-))
missyd
« Reply #153 on: April 12, 2014, 01:35:03 pm »
Thanks a lot!!!! As I found a new job I haven't that much time for the built at the moment. Still hope to have it ready by June/July.
Danielle
missyd
« Reply #154 on: April 14, 2014, 05:48:44 pm »
More work done on the deck!!
Danielle
Umi_Ryuzuki
    • Models and Miniatures
« Reply #155 on: April 14, 2014, 07:20:29 pm »
Love the brasswork mast.  :-))
And the added layer to the decking  :o  thats a layer of detail I probably wouldn't have built.
Great Work.  8)
Oh,...
missyd
« Reply #156 on: April 16, 2014, 05:01:12 am »
Thanks a lot! The added layer on the deck is mandatory to get rid of the water splashing on deck and the water coming out of the 2 forward crab tanks.
Wonderful block to haul in the pots! Can I order one?  ok2
Danielle
Umi_Ryuzuki
« Reply #157 on: April 16, 2014, 06:48:11 am »
Not just yet...
I think what you will need are crabs, Doesn't someone cast crabs?
missyd
« Reply #158 on: April 17, 2014, 05:28:54 am »
Never seen king crabs in 1/32 scale ..... :((
Danielle
tugboyben
  • Kirkleesmodelboatclub
  • HIGHNOON TUG BOAT
« Reply #159 on: April 17, 2014, 07:02:58 am »
« Reply #160 on: April 17, 2014, 08:28:50 am »
They are nothing like king crabs or opies :(( {:-{
Skimmer Fan
« Reply #161 on: April 17, 2014, 08:29:42 am »
Missyd
Lovely work
http://www.macsmouldings.co.uk/page9.php?view=preview&image=4&category=0
This site is worth a look. On his stand at shows he has a crab table set up, I do not know how he does it but the crabs move.
Will see if I can find a video clip.
Skimmer Fan
GAZOU
« Reply #162 on: April 17, 2014, 09:44:27 am »
If you eat Spanish mussels there are many crabs Inside , 5 / 7mm of diameter
You put some granules in the fish for the cat: you have the smell   :-))
missyd
« Reply #163 on: April 18, 2014, 07:00:19 pm »
Good idea but 5-7mm is too small .... {:-{
Planking is finished an I sanded and painted it ... FINISHED! Crab tanks need more paint and finish ....
Danielle
missyd
« Reply #164 on: April 21, 2014, 05:31:31 pm »
Some more work done ...
Props and rudders mounted ... deck with a seal made of liquid rubber ... removable panel mounted
Danielle
Big Ada
« Reply #165 on: April 22, 2014, 07:04:34 pm »
Coming on nicely Danielle.  :-))
Len.
missyd
« Reply #166 on: April 24, 2014, 06:06:46 pm »
Thanks a lot Len!!!! :-))
New pictures of the build! Still working on getting the deck finished.
L-shaped part of the deck made of 2x1.5mm ABS plastic card welded together with acetone.
Wipe away the color method used on the crab tanks.
Danielle
missyd
« Reply #167 on: April 27, 2014, 05:41:32 pm »
Some rust added ....
Ready for the black color ...
...and the result!
Danielle
missyd
« Reply #168 on: May 01, 2014, 03:20:27 pm »
Today I put the CM into the water in the bathtub!!! Needed some 18kg in weight to get her right in the water ...
Danielle
missyd
« Reply #169 on: May 01, 2014, 03:21:18 pm »
Short video made by Anita ...
https://www.youtube.com/watch?v=ip5RSoo6Bos
Danielle
« Reply #170 on: May 01, 2014, 03:56:54 pm »
Great stuff Danielle
The deck and crab tank covers and hatches are spot on.
And she floats  :-)) :-)) :-))
Keep posting please.
Sparky
  • sparky
« Reply #171 on: May 02, 2014, 09:32:51 am »
Always a proud (or scary!) moment when your creation meets the water
for the first time !      :-)
Well done Danielle, your handiwork is superb.
regards, Vic.
missyd
« Reply #172 on: May 02, 2014, 06:56:42 pm »
Thanks a lot Vic and Ned. Actually it wasn't the first time it met the water ... 1st time was months ago ... just to check how stable it would be in the water ...
Pic of then ...
... and now!!!  ok2
Danielle
Umi_Ryuzuki
« Reply #173 on: May 02, 2014, 07:45:37 pm »
For a second, I thought you had built a new cooler for the lake.
missyd
« Reply #174 on: May 04, 2014, 05:27:10 pm »
Good one ....!!!! ok2
Just put on some black color on the pipes in front of Phil's workplace ....
Danielle
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16   Go Up
Page created in 0.029 seconds with 22 queries.
