Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16   Go Down
Author Topic: Building the FV Cornelia Marie  (Read 186484 times)
jarvo
  • Etherow model boat club
Re: Building the FV Cornelia Marie
« Reply #250 on: April 21, 2015, 05:28:14 pm »
Danielle
Please take some pics of the show, been waiting so long for this day
Mark
Tugs are for pulling
missyd
« Reply #251 on: April 26, 2015, 05:54:15 pm »
2 pictures of the first outing of the CM .... more will be added later this week.
Everything went well and the CM is easy to steer and handle on water!!!
BIG SUCCESS!!!!!! Everybody was very happy with my CM and I got TONS OF COMPLIMENTS for it.
>>> I'm very happy <<<
Danielle
jarvo
« Reply #252 on: April 26, 2015, 06:14:50 pm »
Danielle, waited so long for this moment,  SUPERB, she looks so good
Mark
« Reply #253 on: April 26, 2015, 06:21:09 pm »
Agreed..... looks even better on the water
Mark T
« Reply #254 on: April 26, 2015, 06:48:13 pm »
Wow what a great Job it looks amazing now its afloat  :-))
missyd
« Reply #255 on: April 27, 2015, 09:22:30 am »
Thanks a lot my friends!!!!
Some pics from the show ... videos will follow end of the week.
Danielle
cuppa
« Reply #256 on: April 27, 2015, 09:36:30 am »
That looks amazing. A wonderful model.
escipion
« Reply #257 on: April 27, 2015, 05:25:56 pm »
Really a great job,  :-))   Congratulations
missyd
« Reply #258 on: April 27, 2015, 05:28:31 pm »
Thanks a lot to both of you!!!!
Some more pictures ....
Danielle
jarvo
« Reply #259 on: April 27, 2015, 11:05:37 pm »
HI Danielle
Was that water park a normal boating area or was it a special event??
Mark
missyd
« Reply #260 on: April 28, 2015, 03:31:04 am »
Mark it was the annual model-boat-show of a club ... it was held in a outdoor swimming pool(s). One pool for the slow models and one for the racing boats.
Danielle
missyd
« Reply #261 on: April 28, 2015, 12:01:31 pm »
Just a quick question:
The CM is running on two 12V Motors (Igarachi 3657-050, 10-14V, rated voltage 12VDC, noload current 0.25A, load current max. 1.6A, noload 8000rpm) each connected to a 6V/9Ah lead/acid battery. On full speed the CM is about on the right speed but if there is some wind/waves she'll have problems .... more power is needed.
I ordered 2 motors (Igarachi SP3657-030, 3-14V, rated voltage 7.2VDC, noload current 1.6A, load current max. 8A, noload 10500rpm) they will run on the same 6V/9Ah battery.
I hope they will make my CM a little bit faster.
I am right or not?
Danielle
« Reply #262 on: April 28, 2015, 02:07:06 pm »
That's about a 25% increase in unloaded speed so it should give you a little more speed.
If the existing motors are not getting warm in use then another option might be to go for the next size up props.
missyd
« Reply #263 on: April 28, 2015, 02:34:14 pm »
Thanks for the info.
Motors and ESCs are always cool.
Can't go for bigger props as the space is limited to max. 35mm props.
Danielle
« Reply #264 on: April 28, 2015, 02:50:30 pm »
A lot more than 25% surely.
8000@12v. [email protected]
Running on 6v.
missyd
« Reply #265 on: April 28, 2015, 06:45:04 pm »
Ok Ned ... thanks for the information! I'll write here if the new motors are allright.
Danielle
jarvo
« Reply #266 on: April 28, 2015, 10:33:48 pm »
Danielle, a diffferent solution, up-grade the battery to 12v this would increse the revs and give a little more tourque. Would your ESC allow that?
Mark
missyd
« Reply #267 on: April 29, 2015, 04:41:19 am »
No the ESCs do not like 12V even if they should handle 12V .... Graupner Navy VR15 ....
Thats why I switched from 12 to 6V....
Danielle
missyd
« Reply #268 on: April 29, 2015, 08:46:34 am »
Danielle
Corposant
« Reply #269 on: April 29, 2015, 09:55:08 am »
Danielle
Great to see her come to life!
(She'll look even better on slightlly murkier water!)  :-)
missyd
« Reply #270 on: April 30, 2015, 02:33:45 pm »
Thanks a lot Mike.
The real test will be when we are lucky and have a nice day with wind and waves at on of the lakes we can visit with the CM. Murky water, waves and the video/fotoequipment ready ... thats why I built it ... to make pictures just they do in real live.
Danielle
missyd
« Reply #271 on: May 09, 2015, 02:38:10 pm »
Replaced the 12V Motors with some 7.2V much more power for bad weather conditions!
I also relocated the on/off switches for the ESCs. Both can be switched from the outside of the CM without opening a hatch or taking of something.
A test in the bathtub was successful and I hope to take her to a nice lake soon to take some better pictures.
Danielle
« Reply #272 on: May 09, 2015, 09:43:17 pm »
hiya,
Do you then run these on 12 volts.  I have a batch of 7.2 volt motors I was planning to try on a 12 volts supply.  (not flat out, I may add)
I wondered if it did them any harm.
« Reply #273 on: May 09, 2015, 10:36:31 pm »
hiya,
No Ken..... If I remember correctly she mentioned in an earlier post that the motors were running on 6V Lead acid batteries
missyd
« Reply #274 on: May 10, 2015, 06:08:22 am »
Sorry forgot to mention that everything but the 12V LEDs runs on 6V acid lead batteries ...
Danielle
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16   Go Up
