I'm running a Pitman 24v (running on 12v) geared 5.9:1, with propshop 25275 three blade props. I can do all the relevant calculations, but try as I might can't find the rpm of said motor. There is no label (that I can see as it's in the boat), so I don't know the exact model number, but does anybody know a good source to look at for pitman specs. I've tried googling, but can't find my motor.
Also, when calculating rpm / pitch / hull speed, if I run 2 props, do I effectively double the pitch over running a single prop, or increase their combined efficiency - and if so by how much? Or is that too simplistic?
Thanks in advance
Chris
