Author Topic: Parat droppings ( Stabilit-Express cheaper alternative? )  (Read 11328 times)
inertia
« on: April 04, 2013, 07:11:30 pm »
This may be the first and last posting on this subject. We shall see how things progress.
Having made the stand, the next few jobs all seem to involve Stabilit-Express.........but have you SEEN the PRICE of that stuff????? I'm told it's the dog's doo-dahs for sticking wood to ABS and I always try to follow the kit-maker's recommendations, but really! Twenty three quid for 80gm? Is there a better i.e. cheaper alternative? Please forgive my apparent ignorance but I haven't glued wood-to-ABS in a kit before, and my last Graupner build was a 'Taxi' model aircraft in about 1978. Please no speculation - I need to know from someone who's actually found and used a better glue for the job.
DM (Never too old to learn; never too shy to ask).
Re: Parat droppings ( Stabilit-Express cheaper alternative? )
« Reply #1 on: April 04, 2013, 07:32:26 pm »
Balsa cement or ABS/PVC cement, plumbers supplies.
  Regards  Ian
   PS DON'T blather it all ower. :-))
Jerry C
« Reply #2 on: April 04, 2013, 07:49:05 pm »
I used superglue medium and thin viscosity throughout, except for the struts for the blade guard for which I used araldite rapid. After 4 years use I had to re-glue the 2 center struts at the guard. This time I used a hot glue gun.
Jerry.
catengineman
« Reply #3 on: April 04, 2013, 08:45:06 pm »
Built two Parat tugs and on both used Araldite with good to fantastic results
Sub driver
« Reply #4 on: April 04, 2013, 09:04:33 pm »
Uhu plus acrylit
Looks like stabillit, smells like it and you mix it the same ( powder&adhesive).
About 8 quid for 30 grams.
Check out uhu wed site tells you all about it, but it does just about the same as stabbillit ex
Regards sub.
Link added - http://www.uhu.com/en/products/2-component-adhesives/detail/uhu-plus-acrylit2-k-acrylatkleber-1.html?cHash=f22a58aedf213c72125f5ee949790f8b
« Reply #5 on: April 04, 2013, 09:16:57 pm »
Price sounds about the same.
eddiesolo
« Reply #6 on: April 04, 2013, 10:14:23 pm »
One of the best that I used to use was something called p600-it was like no-nails but industrial strength. Stuck anything to anything, didn't react with other materials and once set it was harder than the stuff you bonded. Pity they stopped making it  {:-{ Used it on loads of my models and dioramas, I made sure that they stayed glued.
At the moment I am using up my last tube.
Si:)
« Reply #7 on: April 04, 2013, 11:15:22 pm »
Dave this is what I use all the time for anything fanstastic Glue sticks anything to anything Take a tip from a Welshamn for a change
http://www.ebay.co.uk/itm/Zap-Epoxy-Z-Poxy-15-Minute-Epoxy-4oz-PT-35-/320957443886#ht_808wt_932
Read all about it here
http://www.zapglue.com/epoxy-resins/
Mark A Model World usually has some and you canget some on Sat cant you
RMH
« Reply #8 on: April 04, 2013, 11:31:42 pm »
+1 for uhu acrylit.
Yes it is expensive but used carefully it will last a while, you don't need much to get a good bond but it will fill gaps.  It takes a while to get the mix ratio right but you don't need much powder to get it to set. You get about ten minutes working time and once set the parts are stuck for life. For gluing ABS there is nothing better.
unbuiltnautilus
« Reply #9 on: April 05, 2013, 12:48:50 pm »
Devcon Plastic Welder, two part like an epoxy, but glues and stinks like Stabilit Express, just cheaper...
« Reply #10 on: April 05, 2013, 01:14:54 pm »
the UHU plus is pretty much the same as Stabilit (allegedly they come from the same factory)
Have a look at StarLoc adhesives website
http://www.shop4glue.com/stable-xpress-acrylic-glue-for-plastic-metal-wood-modeling-abs-grp-model-boat-adhesive-402-p.asp
The owner is also a member of this very site
« Reply #11 on: April 05, 2013, 01:41:24 pm »
Yes, I too liked Devcon and easier to use.
My experiments with ABS type glues:
http://www.modelboatmayhem.co.uk/Builds/S130/Part_2.htm
http://www.modelboatmayhem.co.uk/Builds/S130/Part_6.htm
« Reply #12 on: April 05, 2013, 01:58:29 pm »
You-hoo "Hart" is their own Balsa Cement.
  Regards Ian.
Cyberdan
« Reply #13 on: April 05, 2013, 03:44:12 pm »
My understanding is, construction adhesives are a tried solution for ABS to wood up here in Canada we have LePage PL9000, amazing strength for these joints. someone who goes to the same pond with his Parat used it and it's been holding for the past 5 years or so since his build, he also claims that it reduced the rattly sound that these tugs a famous for since the glue remains in that semi hard state giving a slight vibration dampening effect. It sells here for around $8 (5  pounds) for a silicone gun size tube, there must be an equivalent in the UK.
You can buy a tube and try it in a test joint and see if you like it.
« Reply #14 on: April 05, 2013, 05:02:08 pm »
I wonder if this stuff is similar? 'Sticks like ****'
http://www.screwfix.com/p/evo-stik-sticks-like-sh-t-clear-290ml/57252
This also come highly rated...
MODELBOND GEL - http://tinyurl.com/bt3hp6s
« Reply #15 on: April 05, 2013, 05:13:13 pm »
I have tried the modelbond gel and while its very good I found it a little difficult to do a neat job with it (could well be down to my fists of ham and fingers of butter).  I used it to fix the wooden bulkeads and motor mount blocks in my Fibreglass huntsman, Like I said it was not the neatest job but they are certainly not coming apart any time soon!
Howard
« Reply #16 on: April 05, 2013, 07:22:49 pm »
dont know if anyone has tryed this stuff wicks do a tube of ultimite grab about £8 best i have ever used around the house but not in a boat yet. Regards Howard.
Subculture
    • Dive-in to Model submarines
« Reply #17 on: April 05, 2013, 07:48:09 pm »
Stabilit Express, UHU Acrylit, Devcon Plastic Welder I and II, Deluxe materials Super acrylic and Fusion, plus the starloc range of acrylic adhesives are all modified acrylic adhesives. I have not found a better glue than these to be honest, and they stick anything besides the really awkward waxy plastics like polyethylene, which you shouldn't be using for modelmaking anyway, as they don't take paint well either.
The tend to differ in consistency, just like you can get different cyanos etc.
KaMeWa
« Reply #18 on: April 06, 2013, 01:19:48 am »
Amen.  Just about any standard epoxy will do fine, with all abs-abs, abs-wood/whatever -joints....as long as you remember to _roughen_ the surfaces properly.  Grade 80 or 100 sandpaper is not overkill for this :)
I try to avoid using strong solvent-based glues (like UHU Allplast and such) in modelling - they tend to soften the plastic and make visible "bumps" on the other side of joint even after weeks or months. So I´d be very careful when trying any new types like these...
tt1
  • If I only know a little - then I can learn a lot
« Reply #19 on: April 06, 2013, 11:00:43 am »
As Martin said - Evostick Sticks like s**t, it really does! use it very often for sticking motor mounts, deck and beam supports to abs and fibreglass, used it on Moonraker - wood to abs and stuck the decks down with it. Cheap as chips, good initial grab yet movable for positioning and not brittle when set. Sealed all the internal joints of my wavemaster with it, great stuff.
Arrow5
« Reply #20 on: April 06, 2013, 12:45:16 pm »
KaMeWa, you have a PM.
..well can you land on this?
Page created in 0.663 seconds with 22 queries.
