Author Topic: Bow thruster  (Read 2156 times)
bobgrimward
Bow thruster
« on: April 26, 2013, 06:06:01 pm »
I have just started a dutch courage and I intend to fit a bow thruster in her. I have a 30/33X148mm Raboesch but unfortunatly it is too short. Can you buy extention tubes to enlarge the unit otherwise it is back to the drawing board.
Bob Grimward
goBulawayo
Re: Bow thruster
« Reply #1 on: April 26, 2013, 06:45:25 pm »
Might it be possible to buy some tubing that fits either over or into the raboesch tubes and epoxy it in place to lengthen the tubes?
Wayne
Sparky
  • sparky
Re: Bow thruster
« Reply #2 on: April 26, 2013, 07:08:28 pm »
That's the way I'd go.
Vic :-))
norry
Re: Bow thruster
« Reply #3 on: April 26, 2013, 08:26:27 pm »
I,m sure you can buy extensions for the pipes from Raboesch...
What diameter are the pipes ?...
I have in the past used plastic plumbing pipe on a Graupner unit...I sleeved 15mm pipe over the original pipes...
chipchase
Re: Bow thruster
« Reply #4 on: April 26, 2013, 08:49:31 pm »
Here is a link Bob  http://www.cornwallmodelboats.co.uk/acatalog/bow_thrusters.html
not cheap for bits of plastic pipe, I think you would take the advice of Wayne and Norry.
CF-FZG
Re: Bow thruster
« Reply #5 on: April 26, 2013, 09:00:51 pm »
For less than £9 I'd go with the Raboesch extension tubes  :-))
Mark.
Tonka Toys - Big boys toys :)
