Pages: [1] 2 3 4   Go Down
Author Topic: Cragsider Build  (Read 24702 times)
chipchase
Cragsider Build
« on: April 27, 2013, 08:56:41 pm »
Hi all, I thought that I would start posting some photos on another build that I am working on at the moment. :-))
It has been a while since I did an update on my Amity build this is the reason. {-)
The scale of the Cragsider build is 1/24 this makes her 53:67ins long and the beam 15:84ins. I built the plug using the plank on frame method here are some photos.
chipchase
Re: Cragsider Build
« Reply #1 on: April 27, 2013, 09:10:48 pm »
The next two photos show the plug after a lot of preparation and then painted.
dmw_boatboy
  • Model making is a way of life
Re: Cragsider Build
« Reply #3 on: April 27, 2013, 09:15:57 pm »
Hi thats a great looking hull you have made and wow thats some really shiney redish paint what have you used for that?
Have you vac formed or fibre glassed the hull from that?
Lets see some sunshine i would like to go boating!!
Re: Cragsider Build
« Reply #4 on: April 27, 2013, 09:21:40 pm »
Nice one Brian - I've never seen a plug made that way before. By that, I mean with the frames cut in half and glued either side of the fore and aft keel. I've always assumed frames were "slotted" in place - hope that makes sense ? :-)
chipchase
Re: Cragsider Build
« Reply #5 on: April 27, 2013, 09:40:10 pm »
The plug was two pack painted DMW and then a mould was made from the plug to produce the fibre glass hull.
Hi Ray making the hull this way was a first time for  me to, it was a bit time consuming as I braced each frame and then glued.
chipchase
Re: Cragsider Build
« Reply #6 on: May 01, 2013, 07:55:55 am »
Here is a link to last weeks test sail
The last link was not working try this one  :-))
http://www.youtube.com/watch?v=dMDCb2QLNMo
chipchase
Re: Cragsider Build
« Reply #7 on: May 04, 2013, 09:21:55 pm »
Here are two photos showing the progress of the Cragsider build.
bassplayer1
Re: Cragsider Build
« Reply #8 on: May 04, 2013, 09:30:58 pm »
Fantastic work!!!
chipchase
Re: Cragsider Build
« Reply #9 on: May 04, 2013, 10:42:28 pm »
Thanks bassplayer1 here is a photo of her in the early stages. It will give you some idea of her size. {-) {-)
Re: Cragsider Build
« Reply #10 on: May 04, 2013, 11:54:49 pm »
What a monster!  :-))
chipchase
Re: Cragsider Build
« Reply #11 on: May 07, 2013, 09:33:11 pm »
Yes she is going to be a big model Martin, here are a few photos showing the build of the steerable nozzle.
mark w
  • "I stick my neck out for nobody"
Re: Cragsider Build
« Reply #12 on: May 10, 2013, 05:36:57 pm »
Lookin' great  :-)) . Watched the video, looks wonderful. What do you think the finished weight will be?
Mark
"If she can stand it, I can too, play it"
eddiesolo
Re: Cragsider Build
« Reply #13 on: May 10, 2013, 05:45:34 pm »
Now that is one large beast...she looks amazing, some great engineering skills there. She is going to be pretty weighty once done, how are you going to transport her, trailer or van?
Si:)
chipchase
Re: Cragsider Build
« Reply #14 on: May 10, 2013, 10:04:11 pm »
Thanks gents, Mark I think the total weight will be around 5 stone she takes about 4 stone to get her down to the water line.
Eddiesolo I have a hatchback and she fitted in no problem.
chipchase
Re: Cragsider Build
« Reply #15 on: May 10, 2013, 10:54:54 pm »
The outer tube that holds the nozzle was made from alloy and a brass tube fitted into the alloy to act as a sleeve for the nozzle shaft to fit into. The reason for fitting the brass tube is I find that the steel shaft sometimes reacts with the alloy.
chipchase
Re: Cragsider Build
« Reply #16 on: May 28, 2013, 10:57:06 pm »
Hi all here are two photos showing the way that the motor and bed plate are fitted, and two showing some of the deck frames.
mark w
Re: Cragsider Build
« Reply #17 on: May 28, 2013, 11:12:12 pm »
Motor mount looks good  :-)) .
Mark
chipchase
Re: Cragsider Build
« Reply #18 on: May 28, 2013, 11:22:15 pm »
Cheers Mark the rubber in between the motor and the bed plate allowed me to get the right tension on the drive belt.
Gazza
  • If its to windy to fly I'm boating
Re: Cragsider Build
« Reply #19 on: May 29, 2013, 12:29:21 am »
Very nice keep us posted
retired and loving it
chipchase
Re: Cragsider Build
« Reply #20 on: May 29, 2013, 08:26:10 pm »
After filling in between the deck frames with 10mm ply the deck was then covered with 2mm plastic card. I decided to us 1.5mm alloy plate on the stern; the reason for this was the Cragsider had a removable steel plate for access to the Kort head gear I decided to fit the same as it would be easier for repairs if anything happened to the Kort on the model.
Re: Cragsider Build
« Reply #21 on: May 29, 2013, 08:47:36 pm »
It's no wonder, then, that I have difficulty lifting your model boats  <*<
Lovely work Brian - eagerly awaiting the next update  :-))
Re: Cragsider Build
« Reply #22 on: May 29, 2013, 09:02:57 pm »
Hi Brian
I have really enjoyed looking at this and I like the belted motor method. Will the rubber stretch at all and need re tensioning?
chipchase
Re: Cragsider Build
« Reply #23 on: May 29, 2013, 09:20:45 pm »
cheers Ray I will have to try and build them smaller  {-) {-)
chipchase
Re: Cragsider Build
« Reply #24 on: May 29, 2013, 09:39:23 pm »
Hi Brian
Hi Dave, I have used this type of drive on a couple of builds and had no problems up to now, the toothed belts and pulleys are purchased  from MFA and are very good quality, I think it would take quite a lot to stretch the belts.
Pages: [1] 2 3 4   Go Up
Page created in 0.919 seconds with 22 queries.
