Author Topic: flecher destroyer  (Read 2183 times)
regiment
flecher destroyer
« on: May 09, 2013, 12:54:43 pm »
   help wanted what type of battries will i need for my flecher destroyer is has two motors.. printed on them are  no 457 re 385 como drills  thanks
Re: flecher destroyer
« Reply #1 on: May 09, 2013, 10:25:37 pm »
A quick google for  "[size=0px]457 re 385 como drills"[/size] came up with this page - http://www.mfacomodrills.com/pdfs/Miniature%20DC%20motors.pdf
This says that they are 12 volt motors.  Might be a good idea to look for other threads on Fletcher / Blue Devil - someone else is sure to have figured out what weight of battery can be carried.  It will probably need the full 12 volts for the required performance - doing it with NiMH might be better than SLA because it is possible to buy 2 5 cell packs which is easier to put where it is wanted.
« Reply #2 on: May 09, 2013, 11:40:08 pm »
The model has the original models course props.
If you run on 12 volts it will be far to fast.
She was never trialed so I would suggest you start at 6 or 7.2 volts and see how she performs.
I should point out that I know so much about her as I fitted her out.
Page created in 0.017 seconds with 22 queries.
