Comments on chain:
The 3D printed plastic is a natural translucent/white color.
It is a urethane-acrylate, printed with a Multijet type process. Once cleaned, it takes paint quite well.
The multijet process lays down a soft support wax around the part during build. This is gently melted off, then the supplier uses an ultrasonic bath in VEGETABLE OIL to get the last of the wax off. But the oil is left on. So the user needs to gently brush the chain in luke-warm soapy water to get the chain ready for paint.
This plastic chain is NOT recommended for functioning installations, sorry! On-deck display only.
Chain is sized by “wire diameter” (D), even if actual wire is not used in forged or cast links.
Link length is 6x D. Pitch is 4x D.
USS Iowa uses 3.25 inch chain (D).
A modern USN DDG/CG uses about 2.2 inch (D).
WW2 DDs (e.g., Fletcher) uses 1.375 inch (D).
Your ship will vary! Choose wisely.
So far, I have produced chain at:
0.6mm D (about 11 links per inch, the smallest possible in this process);
0.75mm D (about 9.5 LPI);
0.9mm D (about 7.5 LPI);
Other sizes are possible.
I can produce lengths about 2 meters long (varies by link size).
Shipping is from the USA; a box is required to protect the chain, postage can be significant (
www.usps.com)
Pricing is in development… the 0.75mm chain is US$4 per foot. Paypal works well!
