Author Topic: shroud material  (Read 12261 times)
guitar man
shroud material
« on: May 30, 2013, 08:20:50 pm »
Hi all
I am now going to show my lack of knowledge  :embarrassed: Can shroud lines be either wire or chord, if so, is it choice or to do with boats weight or something else altogether i.e sail size. Sorry for my lack of knowledge but any explanation will be appreciated. Many thanks in advance for any comments
As always kind Regards Tony
tony23
  • IOM, Marblehead Yachts
Re: shroud material
« Reply #1 on: May 30, 2013, 08:30:00 pm »
Shrouds are best made from either a fine single strand wire or multi strand wire what you don't want is string or any type of line as that will stretch which is what you don't want to happen with shrouds
triumphjon
Re: shroud material
« Reply #2 on: May 30, 2013, 09:51:08 pm »
many of my larger yachts have dyema cord for the shroud lines , with a bowsie to adjust the tension on them !
hmsantrim
Re: shroud material
« Reply #3 on: May 30, 2013, 11:38:10 pm »
 Hi Tony.
 Depends if the mast is keel or deck stepped.  keel stepped I use cotton brickes chalk line as the mast is supported by the keel step and the deck so what if the shroud stretches a bit, just pull the bowsie along a bit so where`s the problem.
 Deck stepped.  you need the steel wire as the mast has no support except the shrouds as the step is only the mast locating spot.  You will need rigging screws with the hook at one end to go into the shroud plate to tension the wire. On the mast side the wire would be crimped.
Upped a pic to give you an visual idea.
  Frank
mrpenguin
Re: shroud material
« Reply #4 on: May 30, 2013, 11:58:20 pm »
Hi all
Tony, you have not indicated what size the boat is, what type of sailing boat, also the intended use of the boat. This will vary the answer somewhat.
Static models can of course use something that resembles the original rope, often coloured to suit.
Smaller sailboats (say up to one metre) can and do quite successfully use Spectra or Dyneema with bowsies for tensioning. For boats larger than one metre, wire rigging is recommended as it is more reliable and not subject to stretching.
As far the use - if you have a racing boat (eg IOM) that requires accurate sail adjustment and will sail in strong weather then wire rigging is strongly recommended.
Wire rigging is also useful if you are rigging the boat pondside, as it makes it much easier to rig the boat with things in the same position each time.
My personal preferences - for boats one metre and less - I use 100-200 pound Dyneema, available cheap on eBay - I use the heavier breaking strain as it makes the lines easier to handle. Shrouds are adjusted using bowsies made from plastic or aluminium. For my larger boat (a 1.8 metre A Class weighing 15kg all up) I have used all single strand wire rigging with adjustable stainless hooks.
Cheap Dyneema from eBay - http://www.ebay.com.au/itm/DYNEEMA-MAXX-POWER-4-strands-braided-PRO-BRAID-Fishing-Line-GRAY-100M-6lb-100lb-/271075398245?var=570117848006
Wire rigging supplies I have sourced from here:
https://www.radioyachtsuppliesaustralia.com/categories/RIGGING-%28CORD%7B47%7DWIRE%29/Wire/
The Kwik Twist hand tool is expensive but makes a really nice job
Amateur at work...
guitar man
Re: shroud material
« Reply #5 on: May 31, 2013, 09:25:59 am »
Thanks for the replies so far
Mr penguin sorry I should have said the hull is a metre long and the sail is a height of 45 inch the boat is intended to sail but for enjoyment only no racing or such.
Frank that is a nice looking rigging screw any idea were you got from
 Kind regards Tony
mrpenguin
Re: shroud material
« Reply #6 on: May 31, 2013, 01:54:47 pm »
I have used these rigging screws on my A Class - they are excellent
https://www.radioyachtsuppliesaustralia.com/products/Rigging-Screw%2C-Single-End-M3-Thread-Dia.--Part-%23-030%252d030-.html
They are probably overkill for a 1 metre boat in my opinion.
Amateur at work...
JayDee
    • JOHN DOWD
Re: shroud material
« Reply #7 on: May 31, 2013, 02:31:30 pm »
Hello,
Rigging Screws and anything else you would need for a One Metre boat, from an Expert!.
Try    http://www.housemartinsails.co.uk/hullfittingsa.html
John,  :-))
http://www.john-dowd.
john44
Re: shroud material
« Reply #8 on: May 31, 2013, 04:24:53 pm »
Hello,
John,  :-))
I agree, Martin is a first class bloke I had all my IOM sails rigging fixings etc. from him.
and he would make sure you are fitted out with the correct parts
for your needs.
john
nemesis
Re: shroud material
« Reply #9 on: June 15, 2013, 12:46:39 pm »
Hi, go and visit your local fishing tackle shop, you may find all you need there as regards to rigging cord and fittings. Nemesis
rickles23
    • Royal Navy Commandos
Re: shroud material
« Reply #10 on: June 15, 2013, 02:33:55 pm »
The plastic covered wire from a bait shop is the go.
Boomer
Re: shroud material
« Reply #11 on: September 23, 2013, 09:52:46 pm »
Lots of good suggestions - I think a lot of this comes down to personal taste as much as function.
On my boats of 900mm to 1 Meter I have come to standardize using a nylon coated 1 x 7 strand SS (fishing) leader (30 lb. test) using matching crimping sleeves are connected to SS rigging screws from Sailsetc.com model #30.030 Mrpenguin's picture shows the #30.035 which is just slightly larger.
I am sure there are many brands of leader around the globe and don't think one brand is significantly better than another I use Surflon because that is what my local tackle shop stocks. I use the "bright" finish. Looks great in the sun light. I've tried heavier test but found the 30 lb. test was easier to use and fits nicely through the spreaders.
Posted a few images that may be of interest. The rigging screws as pointed out, make mast tear down and set up a snap. Tuning is made easier as well. The use of double locking nuts permit you lock in you set up each time you sail. Plus this combination yields a strong, non-stretch shroud arrangement that looks great too.
Boomer
rickles23
Re: shroud material
« Reply #12 on: September 24, 2013, 08:34:47 am »
I am setting up the Marblehead to use the new Spectra line.
Re: shroud material
« Reply #13 on: September 24, 2013, 10:25:17 am »
Because of my scale sail models I use Dacron, it is a non-stretch cord. It is braided and looks more natural on some scale sail models as it will dye. It also ties nicely around and through dead eyes. As a result of spool sizes I have a surplus for other models.
Saylee
Re: shroud material
« Reply #14 on: October 16, 2013, 08:47:45 pm »
Boomer,
Great suggestions in your post. One question: have you found any local suppliers or hardware stores who carry similar turnbuckles/rigging screws like those from SAILSetc? Really like their products, but would love to have options stateside as to not have to wait for  yet one more item to be shipped and keeping the build delayed.
Thanks!
Boomer
Re: shroud material
« Reply #15 on: October 16, 2013, 10:19:47 pm »
Boomer,
Thanks!
[/quot
You can get them from Midwest Model Yachting.  His item is #130. He is a sailsetc dealer. He is a little more expensive being a dealer. I buy from sailsetc direct and have had good service from them. Midwest has been good as well.
Boomer
Saylee
Re: shroud material
« Reply #16 on: October 17, 2013, 01:54:45 am »
Thanks for the tip! Good to know there are options. Time to do a quick price check and see what comes up.
slug
Re: shroud material
« Reply #17 on: October 18, 2013, 07:31:30 am »
if you buy wire from a tackle shop you can get packets and they come with crimps,saves messing about.....tony
tiaki
Re: shroud material
« Reply #18 on: October 19, 2013, 07:06:03 pm »
 After using stainless steel tracer for several years on Marblehead yachts I have converted to Dacron for all my yachts from 1.6meter to RG 65 lengths. A lot simpler, a lot cheaper and no threat of kinks in the cables. I've yet to see Dacron stretch and do use fingernail polish on all the knots as a Loctite, the colour is dependant on the better halves discards!
Boomer
Re: shroud material
« Reply #19 on: October 19, 2013, 09:10:53 pm »
I have never experienced anything close to a kink in a the SS leader I've used. As far as it being expensive, the brand I have been using is really not expensive at all. As I stated earlier, it is really more a personal preference. It is not for everyone, but I like the results I've had over the years so I stay with it.  :-))
Boomer
tiaki
Re: shroud material
« Reply #20 on: October 21, 2013, 06:07:23 pm »
Your cable may not be "expensive"  Boomer, but you conveniently forgot the sum total of all the over ancillary fittings required to make it work. You can't beat some Dacron, bowsie and stainless hook for cost. If you are handy enough to make the bowsie and hook then there's a big difference, KISS is the way.
vnkiwi
Re: shroud material
« Reply #21 on: October 21, 2013, 06:40:54 pm »
All a matter of personal choice, and to a degree availability.
KISS has been the underlying principle during my career in design, and I use a variety of materials on my rigging, to suit the application,  ease of transport and pond side rigging
All on probably, the smallest budget around
Enjoy your chosen hobby with like minded friends
cheers
vnkiwi   :-))
Boomer
Re: shroud material
« Reply #22 on: October 21, 2013, 08:58:43 pm »
KISS is good for sure no question!  But as I said, it is a matter of personal choice/taste/budget. I am retired now and spending habits for me are a bit different than in my working days.  I like most, like to find the best values for my money, but don't feel the cost of the hardware it takes to set up a few my RC sailboats with SS leader and SS rigging screws to be extravagant. At this point - it works for me. :-))
If you want extravagance you should check out my lovely wife's closet!  O0 Now that's another subject all together.  <:(
Compared to the hobbies of my youth - RC sailing is about the best bang for my "bucks" yet.
It's all good!
Boomer :-)
After 43 years together, I have accepted my circumstances.  %%
Page created in 0.684 seconds with 21 queries.
