Author Topic: WATCH YOUR WIRES!  (Read 4274 times)
WATCH YOUR WIRES!
« on: June 01, 2013, 03:17:27 pm »
A little bit miffed right now.  But this should go with in the beginners section as its such a STUPID mistake to make
Bought some micro RC gear from hobby king in order to RC a little plastic kit I have.
Shopping list consisted of the following items
Orange RX R415 Micro
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18827
HK 3A Brushed ESC
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11885
Micro linear servo
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11737
And a sincle cell lipo
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20386
nice little setup, decided I'd get started and bind the RX to my transmitter
connected ESC to RX then connected battery.... strange blue smoke escaped from the RX, disconnected the battery quick sharp but alas damage was done.
reason being was the lipo was wired opposite to the ESC so while the connector fitted perfectly it was in fact reversed and the orange RX didn't like it.
Cant believe I didn't check before hand and joy of joys the RX is now on backorder
I'm off to sit in the dunces corner
Covert
Re: WATCH YOUR WIRES!
« Reply #1 on: June 01, 2013, 03:54:21 pm »
Did this last week with a 1/8 buggy, plugged my lipo in the wrong way round >>:-(
Doesnt take much to smoke a £100 esc
« Reply #2 on: June 01, 2013, 04:00:19 pm »
you would think they would put some kind of reverse polarity protection in there.... OK maybe not on a $10 ESC but maybe on a $100 one.
Ah well one lives and learns.... Guess I better order a new ESC just in case
john44
« Reply #3 on: June 01, 2013, 04:16:47 pm »
costly error guys. <:(
But those who have never made a mistake
have never made anything.
john
unbuiltnautilus
« Reply #4 on: June 01, 2013, 04:18:01 pm »
Two hours ago I was removing a tapping screw from a customers nylon engine mount, by boiling it and hammering it out of the nylon when soft. Following a distraction, this dissolved into filling the shop with smoke and activating the smoke alarm, about 130Db, while melting the motor mount into an unrecognisable lump, that woke everyone up!!
Robin smith
« Reply #5 on: June 22, 2013, 09:58:00 am »
its good to see I am not the only one that makes mistakes.
Mad_Mike
  • Lincolnshire
« Reply #6 on: June 22, 2013, 01:27:01 pm »
I was running to parralell lipos in my cat. 2 plugs for 2 lipos and 2 plugs on a lead to the esc. 4 plugs in total. Not whatching what i was doing i joined both lipos togeather and turned the plugs into molten metal.
justboatonic
« Reply #8 on: June 22, 2013, 09:55:51 pm »
Hmmmm. Last night I was putting the HXT 4mm connectors on an ESC. When I'd just about finished soldering the connector on, I realised I'd put the things on the wrong wires so had to de solder them and start all over again. Grrrrrr, easy done even when concentrating.
Peter Fitness
« Reply #9 on: June 22, 2013, 10:44:48 pm »
john44
« Reply #10 on: June 22, 2013, 10:51:07 pm »
I had a UBEC feeding my Rx and my Action Noisy Thing.To keep the voltage at 5V
I had a problem setting up my brushless ESC so instead of going to get my
Tx to sort it out I decided to use my servo tester instead so with
the ESC disconnected from the Rx I had to fit the BEC red wire back into
the ESC plug, all went well, set the thing up unplugged the servo tester
Went for dinner, Came back to the workshop Tx in hand,
 Plugged the ESC back into the RX switched on the Tx
connected the main battery and nothing worked
the Rx and Noisy thing won,t work.The led on the UBEC went dim.
You guessed it I did,nt remove the red wire from the ESC bec  :embarrassed:
and that idiot mistake has cost me an Rx and a Noisy Thing
Any one need a 15w amp <:(
john
irishcarguy
« Reply #11 on: June 23, 2013, 07:56:51 am »
Dave will repair the noisy thing for you if you send it to the Component Shop who now sell ACTion gear & give good service too.Mick B.
Mick B.
irishcarguy
« Reply #12 on: June 23, 2013, 07:59:55 am »
I don't make mistakes, I just find hundreds of ways to do things wrong, Mick B.
Mick B.
Page created in 0.643 seconds with 22 queries.
