Author Topic: Hull and top Deck Joining  (Read 3315 times)
Brum
« on: July 31, 2013, 09:19:05 pm »
I have a Los Angeles Sub from MMB,  nice boat, just fitting all the parts. looking for ideas how to hold the deck/hull togther. New at this so would welcome good advice.
many thanks
Brum
george
Re: Hull and top Deck Joining
« Reply #1 on: August 08, 2013, 06:45:44 am »
  Hello
 Lots of people use the Z cut for the modern nuke hulls with an added lip on the front so the front has something to hold onto and at the rear they use another lip which has a screw hidden by something on top to secure that end.
 George
Big Ada
« Reply #2 on: August 08, 2013, 05:43:24 pm »
Magnets?
george
« Reply #3 on: August 08, 2013, 10:22:09 pm »
 Hello Again
 Just my thoughts about magnets. Would they have any affects on the electronics? Also with foam used for keeping the hull at surface trim as well as the weight below that, could you run the risk of the submarine splitting in two halves?
 George
Hellboy Paul
« Reply #4 on: August 08, 2013, 10:43:30 pm »
Might be too obvious but my first thought would be to contact Mark at MMB ... After all he makes 'em!!!!! O0 O0
Paul..
Brum
« Reply #5 on: August 08, 2013, 10:52:06 pm »
Thanks for all your comments.
Have contact Mark on this just opening it up to see if another good ideas where around.
Brum
Sub driver
« Reply #6 on: August 08, 2013, 11:38:52 pm »
Indexing lip at the front, screw at the rear disguised as a bollard / capstan etc at the rear.Or the other way around
You will find that with a sub you will get some  surface dwellers run over you unless you sail on a subs only day / lake. And the first thing that gets hit is the tower / deck.
Make sure its well secured or you may loose it.
Regards.
Sub.
Brum
« Reply #7 on: August 09, 2013, 02:28:29 am »
Got it many thanks
Page created in 0.112 seconds with 21 queries.
