Author Topic: Functional Davit...  (Read 3399 times)
Gajjark
Functional Davit...
« on: August 22, 2013, 02:20:22 pm »
Hi to all champs...
Need one help from you.
I want to make a working/functional model of gravity Davit for one project. Size would be 3 to 4 feet. Looking for design and material.
Can any one support?
Re: Functional Davit...
« Reply #1 on: August 22, 2013, 02:48:30 pm »
here you go......also google Wellin  gravity davits, or just gravity davits.
neil.
http://en.wikipedia.org/wiki/Davit
Gajjark
« Reply #2 on: August 22, 2013, 03:08:15 pm »
Thanks sir.
But looking for plan or somthing like through which I can move forward.
eddiesolo
« Reply #3 on: August 22, 2013, 11:52:59 pm »
There is this: http://www.bst-tsb.gc.ca/eng/rapports-reports/marine/2000/m00w0265/m00w0265.asp
There is this: http://forshipbuilding.com/equipment/lifesaving-appliance/
There is this: [size=78%]http://dspace.cusat.ac.in/jspui/bitstream/123456789/4482/1/Lifeboat%20launching%20gravity%20davit.pdf[/size]
There is this: [/size][size=78%]http://www.yzjssb.com/en/XL1-2.asp?productid=941[/size]
All these may give you ideas or maybe you could contact the manufacturers to get specs.
Si:)
Gajjark
« Reply #4 on: August 23, 2013, 08:57:45 am »
thank You very much for your prompt support. Its good enough, 3rd link was downloaded and other are also very useful.
eddiesolo
« Reply #5 on: August 23, 2013, 05:17:39 pm »
No problems, glad they gave you some advice.
Si:)
eddiesolo
« Reply #6 on: August 23, 2013, 05:36:23 pm »
Just to add, you mentioned material. As it is 3/4 ft high making it out of steel may render it too heavy if you have to lug it about. So maybe you could make it out of wood, or moulded plastic. If you're wanting it to be a miniature replica then obviously welded steel sections are going to have to be used, I suppose you could house it on wooden plinth with wheels on for ease of transportation.
Si:)
Gajjark
« Reply #7 on: August 28, 2013, 09:30:41 am »
Yes,
It is for one project. And will be used for long time so I am planning to use ss material. Will make a boat from balsa and base would be thick ply.
Want to make a close lifeboat also if any one have design or plan please help???!!!
Page created in 0.096 seconds with 22 queries.
