The ESC needs to be calibrated to work with the particular transmitter.Put the mtronics into program mode with the stick at neutral. Move the stick to full forward, let it figure that, move the stick to full reverse, let it figure that, when the stick is back at centre, everything should work properly, but only on that transmitter. Any other transmitter is likely to be a little bit different and the ESC will need recalibrating to work properly with it.
